C32 AMG coolent loss
Old Feb 3, 2011 | 03:40 PM
  #51
Newzchspy's Avatar
PLAID
Originally Posted by Dingleberry
burn the car to the ground, collect insurance payout.
Yeah good advice and GO Straight to jail.....................
Ever get her properly repaired after all these months??
Old Feb 4, 2011 | 04:34 PM
  #52
andya34's Avatar
AQUIRED A C63 AMG PPP
well both heads have been reskimmed as the new mechanics say they were not perfectly done but theres still no evidence of that being the cause of the coolent loss, even though they say it is most likly as the gaskets used are metal and so the serfice must be straight, but i dont want to put the engine together again and still have a problem because then i will have to get it striped again to test the block so im gonna get the block taken out and tested whilst the heads are off and if the block tests ok then , well it must be because the heads werent perfectly skimmed............the saga continues
Old Feb 5, 2011 | 04:31 PM
  #53
andya34's Avatar
Originally Posted by boohooramblers
1. How much coolant are you losing (at least guestimate) and how long does it take to lose this quantity?
2. Is coolant lost when you drive the car?
I guess what I'm getting at is - have you tested the obvious? If you have another car that you can use, fill up the coolant system and leave it in an area for a period of time where you can monitor for any coolant loss on the ground. That may indicate leakages at hosing or the heat exchanger.
Alternatively, it may indicate a leak in the main coolant system - i.e. the main radiator / heat exchanger and associated plumbing.
3. You said your mechanic checked the intake runners and there are no signs of coolant caked on the sides of the runners.
You also alluded to the fact that no coolant is evident in the valley between the heads.
It appears as if you only have two other real possibilities:
A. The head gasket job you had done wasn't done correctly or else there was underlying damage.
Just for giggles, remove the oil cap and take a look inside. If you don't see any signs of coolant mixture, change your oil and inspect it.
B. The intercooler is in fact compromised and coolant is leaking from that.
Since it seems that you have no other options or answers at this stage, remove the supercharger and intercooler (not a difficult job by the way) and test the integrity of the intercooler.
Pressure test the unit as you would for a radiator and test at various pressures. Place the intercooler into a container of water, apply pressure and look for air bubbles.
well im having the heads redone at the moment .....but although they were not skimmed properly and they were not 100% there still were no sighns of any leak so i think instead of putting the engine back again im gona get the block tested and recon the engine......what else could it be its got to be the block
Old Feb 17, 2011 | 07:22 PM
  #54
andya34's Avatar
well had the block tested and iy aint that...................either so i give up
Old Feb 17, 2011 | 09:16 PM
  #55
Newzchspy's Avatar
PLAID
Did we exclude the IC???
Old Feb 18, 2011 | 04:10 AM
  #56
andya34's Avatar
do you mean intercooler if so i had it pressure tested and it was fine....
Old Feb 19, 2011 | 04:50 PM
  #57
andya34's Avatar
coolent loss
well the head gasket was not done right thats why it lost wayer again.....12months later
Well i now had heads redone and the block crack tested and it aint that the block is fine.....so it must be the charge cooler ,,, but ive tested it and its not showing sighns of leakagecould it still be that??
Old May 15, 2011 | 06:30 PM
  #58
andya34's Avatar
everyone ....my problem is now fixed...the heads when previously skimmed were not skimmed right so since i had them redone and engine assembled it now does not lose any water 14months later...god i must love this car
Old May 15, 2011 | 06:56 PM
  #59
Lenin's Avatar
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
So Biscuit and boohooramblers were right. to both.
Old May 17, 2011 | 09:46 PM
  #60
spatton's Avatar
2004 C32 AMG - 2009 C300 Sport
Originally Posted by Lenin
I never heard of this and I don't see how it can happen.
Is that what you have? How much oil? What color? At the bottom or floating?
i have a slight brown/black ring in my coolant reservoir floating at the top....what could be causing this?
not very thick at all you cant tell by looking in the cap really you can just see the color change from the outside its like 1/16" maybe a tad more...
Old Jul 23, 2011 | 12:05 AM
  #61
flysmith's Avatar
SLK32
Any chance you can get coolant in the engine via the coolant-oil heat exchanger that sits next to the oil filter? I've got a small coolant leak. No emulsification of the oil, but an overnight pressure check resulted in coolant in the bottom of the oil pan.
Old Jul 27, 2011 | 05:50 PM
  #62
Newzchspy's Avatar
PLAID
Originally Posted by Lenin;4674117[B
]So Biscuit and boohooramblers were right. to both.
[/B]
Not really, problem still exists!!
Old Jul 28, 2011 | 07:19 AM
  #63
Lenin's Avatar
Originally Posted by Newzchspy
[/U][/I][/B]
And you are saying it because ..... If that's the case, it's very unfortunate.
