Rear doors stay locked upon exit.
2006 C55
I'm trying to figure out how to make it so when I put the car in park and cut it off the rear doors unlock with the front doors. I'm assuming that I've just got some setting wrong or something, but I can't figure it out and it's a pain since I seem to always put my key in my pocket and then have to get it back out to unlock the car to get the twins out. The weird thing is that it doesn't always do this...about 1 in every 15 times the doors unlock with the fronts automatically. Any help guys?
1 Post
'03 C32, '08 ML63
At least on the C32 (well, mine anyways) when the drivers side door opens all other doors remain locked. But when the passenger door is opened the back doors unlock.
Not sure if it's something you can change down in the menus somewhere or not though.
2016 Chevrolet SS, 2006 Cadillac STS-V
You sure both front doors unlock? I'd say only about half of hte time will mine unlock the other three doors when I get out. I haven't figured out what the trick is to when it will and won't unlock the rest of the doors and the dealer couldn't figure it out either. Now my 2006 C230 I traded in would unlock the other three doors every time I opened the driver door.
Same here, half the time the other three doors don't unlock. I still have yet to figure it out, I think it's a glitch.
Also, mine will rarely not lock the doors when you start driving.
I have the same issue, it started when I trained the key fobs to unlock the driver’s door with one click and open all 4 with two clicks. If you press and hold the lock and unlock button on your fob for about 5 sec until the light on the fob blinks it will switch the unlocking and should fix the problem (hopefully).
2006 C55
