C32 - Pulley & ECU Mod & Heat Exchanger (Eurocharged) - Arrived today :)
Old Mar 4, 2011 | 01:34 PM
KRob3's Avatar
'03 C32 Black
So what would be a good price for these mods? 185mm pulleys, tune, heat exchanger, and pulley saver kit? (did I forget anything?)
Also, how much to install all this stuff? I'm in the Sacramento area if that makes a difference.
I'm just trying to get an estimate on the total cost - I'd really like to mod my car, but don't want to get in over my head financially.
Old Mar 4, 2011 | 02:18 PM
Newzchspy's Avatar
PLAID
$1,500-$2000 MAX!! + a lil for install if you can't DIY!!
Old Mar 4, 2011 | 03:43 PM
KRob3's Avatar
'03 C32 Black
$1500-$2000 sounds about right, plus another $500 to install?
Old Mar 4, 2011 | 07:48 PM
ByeTurboS4's Avatar
'02 C32 ///AMG, 2000 BiTurbo Audi S4(RIP)
So I'm getting the exact same package from EC. What heat exchanger did you get, the Eurocharged beefed up direct c32 replacement or their E55 HE? I haven't figured out if their E55 HE is just OEM or a beefed up version of the of the E55. I just want the best heat exchanger possible, but I definitely prefer something that lines up exactly with stock mounting points. I don't wanna have to mess with brackets and the like.
Old Mar 7, 2011 | 11:41 PM
ByeTurboS4's Avatar
If you did get the E55 HE (which is an upgrade from oem E55 I found out) can you tell me how the in stall was? Ill be interested in how the whole thing went.
You should think about the pulley saver kit and an an upgraded intercooler pump.
Old Mar 8, 2011 | 01:20 AM
johnng117's Avatar
2002 C32 AMG
I got the C32 replacement, it should fit without any mods. I will recommend to change your pump while your at it. I'm just running the Bosch pump, its works fine.
