anyone have experience with the mercedes smart key starter?
for those that don't know, the mercedes smart key starter is a plug and play module for our cars that allow us to remote start our cars with our factory keys and control from our smart phones. i'm getting it next week for an unbelievable price compared to its 799 retail +install price unless someone tells me they had bad experience with it. thanks in advance
I had mines in going on a month and haven't had any issues yet. The only thing on my mind is that I hope it doesn't cause damage to my starter.
Originally Posted by Rboosting
(Post 4691806)
Well these also work on a C32?
where can i get one? and what year and models do they work on?
Edit: BS: 2003 and up CRAP! |
Originally Posted by WaveyKat
(Post 4692323)
Edit:
it'll work on the 03+ c32, i couldn't tell you why you couldn't do it on earlier models. if you were near me, you could buy it from me. i'm getting it done in a few hours
i wonder whats the difference and why it cant work.. i have an 05 SAM i can switch out if thats the Problem :-)..
How much are they and please share the installation process.
thanks |
Originally Posted by michael kuzni
(Post 4691694)
(Post 4691694)
I assume its this company: www.smartkeystarter.com They are based (MidCity Engineering) out of Chicago. Guess I'll have to call............ COMPATIBILITY CHART The SmartKey Starter system is designed to integrate seamlessly with all of the most popular models. **Coming Soon: SL, early S & CL Models, & Sprinter!** OPERATION AND FEATURES: TRULY PLUG & PLAY USING MB PLUGS - NO CUTTING WIRES! NO ADDITIONAL FACTORY KEY NEEDED WORKS WITH THE TOUCH OF THE PANIC BUTTON PANIC SWITCH STILL FUNCTIONAL ALL FACTORY FEATURES REMAIN THE SAME WORKS ON HYBRIDS AND DIESELS WORKS ON KEYLESS AND KEYLESS GO MODELS COUNT TIME RUN TIME ON CLUSTER (SOME MODELS) RUN TIME 15 MINUTES THEN SHUTS DOWN. DOORS REMAIN LOCKED WHEN RUNNING FLASHING LIGHTS CONFIRM VEHICLE RUNNING DIAGNOSTIC VISUAL FLASH IF NO START VALET SWITCH - WHITE DOT SIDE - REMOTE START ON / OTHER IN VALET SHUT DOWN SAFETY FEATURES: BREAK DEPRESSED HIGH RPM INCREASE HOOD OPENED 5 CYCLE SHUT DOWN: SYSTEM ALLOWS 5 STARTS BEFORE ZONING OUT SYSTEM PERFECT IF SOMEONE IS "PLAYING" WITH THE KEYS. TURN CAR ON THEN OFF RESETTING 5 MORE STARTS. |
Originally Posted by Newzchspy
(Post 4692582)
If you don't mind, who'd you get it from? I've always wanted this for "cold weather" starting.............
Originally Posted by Quicktwinturbo
(Post 4692580)
thanks |
(Post 4692819)
it's supposed to be plug and play and just tap power, but i THINK you just plug into the ecu and it does its thing. i just hope it doesn't erase my flash if that's the case.
If it does erase the Jerry Tune, you can always get a SB to make your car quicker/faster!:smash: |
(Post 4692981)
[/u][/i][/b]
