Is my Supercharger Friction Plate worn out? <PICS>
Old Sep 17, 2011 | 01:31 PM
mikev7's Avatar
C32 AMG Ram 1500 4x4 GSXR600R Track Bike
I pulled the supercharger wheel today to get a new bearing pressed in. I have a prob though. I don't know if the friction plate is shot or not. It looks worn but I can't find any pictures of new ones. I been looking for a while. Anyone know if this is in spec? I would like pictures and links please? Mmmmkay..
Old Sep 17, 2011 | 06:58 PM
mikev7's Avatar
I know it looks worn out but the metal plates are supposed to touch and there's little tolerance between them. It's like 1 mm or something. Trying to find if it's out of spec.
Old Sep 17, 2011 | 07:12 PM
320 dreamer's Avatar
2003 porsche 996 turbo
. the wear is why you get the clutch chirp. take some emory cloth and clean both sides up and reinstall and check the gap. as close as possible without touching. you will be fine
Old Sep 17, 2011 | 07:51 PM
mikev7's Avatar
do you know the exact clearance?
Old Sep 17, 2011 | 09:54 PM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Seems there’s no unusual wear occurring on yours.
Clearance specification is .25mm to .30mm. Mine when fitting a fresh bearing at ~85,000 miles:
Is my Supercharger Friction Plate worn out? &lt;PICS&gt;-c32superchargerpulleysnout.jpg
Is my Supercharger Friction Plate worn out? &lt;PICS&gt;-c32pulleygauge1.jpg
Is my Supercharger Friction Plate worn out? &lt;PICS&gt;-c32clutchspecification.jpg
Old Sep 18, 2011 | 03:33 AM
mikev7's Avatar
I'm gonna take it back off tomorrow and correct the spacing.
Old Feb 4, 2016 | 01:08 PM
jvakos's Avatar
E63 SL55 996TT C5Z06
Old thread sorry to dig up but had a question....
I just took off my supercharger pulley and checked the back of it and it looks really worn similar to what you see in these pics from other posters - anyone know what the difference is in the black metal rings vs silver metal colored rings?
I am asking because I was going to try lightly sanding down the wear marks with some very fine sandpaper but not sure if you should avoid touching the black ring area vs silver ring area (or if that even matters).
I am doing this based on what several other posters have suggested as a temporary fix to the loud supercharger "chirp" that i've had ever since installing my 178mm crank pulley, but never found a fix for.
Old Feb 4, 2016 | 03:36 PM
Morphh's Avatar
C32 amg
I know there are shims u can get to stop it from rubbing, is the belt slipping? the chirp there only on full throttle?
I wouldn't sand anything I would use the shims
Old Feb 4, 2016 | 04:48 PM
jvakos's Avatar
Morphh - yeah the chirp is most noticeable when driving at low speeds and i push the pedal about 50% or more and the acceleration kicks in and that annoying chirp comes. it is a constant sound as you accelerate and changes depending on how much i press the accelerator while the SC is engaged. if cruising at 65mph and then i hit the pedal to full kick down you also hear it for sure then until going back to cruising speed.... this noise is making me nuts!
Old Feb 4, 2016 | 05:40 PM
Morphh's Avatar
C32 amg
2003 Mercedes c32 amg supercharger chirping noise - YouTube
I would check ur belt tensioner, mine used to make a clicking chirping sound cause it was
worn out, mine would click. U have 65mm sc pulley, I think u might need 1 shim. My 65mm did not need any shims
It's when car is under load it seems like, I would check tensioner mine would similar noise
Old Feb 4, 2016 | 07:19 PM
Morphh's Avatar
C32 amg
The only things making a chirping noise in my car where the front brake pads cheap ones with no shims and my belt tensioner, I hope this helps u
