ticking sound in the engine bay (c32 amg)
I have this ticking noise coming from engine bay but its the engine sfunds like electrical issue, I made video showing exactly where its coming. Does anyone know what that is?
Video; https://www.youtube.com/watch?v=HIrX...e_gdata_player |
My car makes the same noise. It's coming from that black box with the 6 tubes. I believe it's the ABS purge valve. (Someone correct me if I'm wrong)
I usually notice mine most often when in the drive thru. But it's done it every since I've had the car. Comes and goes and seems to be normal. |
It's ok
I've also got the same noise. Haven't noticed any problems yet.
Thank god I'm alone with this sound, I feel better knowing its normal, Thands guys.
Yeah, normal. I took my car to the dealer at least 5 times cause of it. I just tell people its a diesel.
Same here so i guess its normal.
Possible Fuse
So my C32 starting making the ticking sound about 3 days ago. I was coming to terms with a big repair bill when a penny fell into my cigeratte lighter. While attempting to remove it I blew a fuse. Normally I would research exactly which fuse needed replacing, but I just starting pulling fuses from the side panel inside the cabin. I found a blown 25 watt fuse and replaced it. My lighter didn't not power up, but the ticking stopped! I'm not sure what the fuse control, but the sound stopped IMMEDIATELY. So, if you start experiencing a ticking sound, check your fuses...the lighter fuse is in the engine bay, btw.
Originally Posted by Deliciousanimal
(Post 7024791)
Originally Posted by Rocman8
(Post 7024940)
What fuse slot was the 25a fuse in?
Fuse slot
I'd have to look and see
