C32 failing emissions test
Old Apr 23, 2012 | 08:38 PM
Hjartarson's Avatar
2002 C32 AMG
Hi all,
I'm having some issues renewing my license plates. The process requires a tailpipe reading at idle RPM and another at ca 2000 RPM. My car is failing these tests miserably. The readings show about 4.5% co2 in both tests, but it should be <0.5%.
I've replaced the spark plugs and wires, as well as the upper oxygen sensors. I've taken the car to 2 different mechanics and they are both baffled. The car throws no emission related codes at all. The cats are fine according to the official inspectors.
I tried the search function, but I didn't find anything useful. Has anyone encountered this problem?
Old Apr 24, 2012 | 12:28 AM
gt4awd's Avatar
2005 Pontiac GTO 6.0 LS2 - Blue
Do you have it tuned? Maybe running rich is causing the issue. I would also find a different emissions shop to test again.
Old Apr 24, 2012 | 06:33 AM
Hjartarson's Avatar
2002 C32 AMG
It's stock and the emissions have been tested in 3 different places.
Old Apr 24, 2012 | 08:26 AM
gt4awd's Avatar
Right away would assume it's the catalytic converters. I know the mechanics said it's not but how did they diagnose that? You can't always trust the opinion of a mechanic... How many miles does your C32 have?
Old Apr 24, 2012 | 10:58 AM
Hjartarson's Avatar
2002 C32 AMG
I'm not sure how they diagnosed it, but the official state inspectors said that the cats were ok. Car has 80k miles.
Old Apr 24, 2012 | 12:52 PM
Zeppelin's Avatar
C32
You must mean your CO% was at 4.5, not the CO2. As the CO2 should be in the 5-15% range.
Only time I have had my CO% higher than like 0.6% is when I had a bad Cat Converter on my Honda. It also had sky high HC. Not saying that is it but there is a test they can run to see if it is a bad Cat.
Old Nov 22, 2012 | 01:12 AM
evanoel's Avatar
c32 amg
Some news
Hi Hjartarson,
I have exactly the same problem:
- failing emissions test
- No code on the OBD
Did you find a solution to your problem?
Thanks!
Old Oct 17, 2013 | 10:54 AM
wc124's Avatar
c32 amg, w202, w124
Emissions test
Originally Posted by evanoel
Hi Hjartarson,
Thanks!
Hi Hjartarson and Evanoel,
Same problem, how did you solve that problem?
Old Oct 21, 2013 | 02:00 PM
02C32guy's Avatar
2005 E55
When this happened to me, the culprit was a bad coil pack.
Old Oct 22, 2013 | 04:38 PM
wc124's Avatar
c32 amg, w202, w124
Thanks for your advice. How did you find out that solution / diagnosis? Should "Star" or "Autocom" show something? I´m really frustrated to find out solution for a "high emissions values". "Diagnostic tools" show no malfunction.
Old Oct 28, 2013 | 09:58 AM
02C32guy's Avatar
2005 E55
The star didn't really show anything other than an emissions code. I went to change the plugs and wires to get it to pass emissions and when I did, I saw that one of the coil packs was corroded.
Old Oct 29, 2013 | 05:17 PM
wc124's Avatar
c32 amg, w202, w124
"Star" should be show malfunction of coil packs?
Old Oct 30, 2013 | 04:27 PM
evanoel's Avatar
c32 amg
Hi all,
From my side, no solution yet. My problem with the coil pack is to detect the issue. Anyway, I will try a visual inspection... A full change, without evidence, is risky.
Thanks for activating this subject!
Old Sep 26, 2019 | 04:11 PM
NTX's Avatar
NTX
C32 AMG
Refloating!
Sorry about refloating that thread pals! I have the same problem, it is driving me crazy.... Anyone could solve it at last?
Thanks in advance!
