Cut off, now car suffers vibrations
Old Oct 2, 2013 | 01:01 PM
DAzzi's Avatar
'05 C55 AMG
Good day All, New '05 C55 Owner here. Had to swerve hard the other day to avoid being side-swipped. Driver side of car drove up up a meridian with a soft curb. No visual damage to the wheel, wheel bearining seems fine. Now I am now experiencing driveline vibrations, vibrations front the driver wheel and occasional thunking noise from driver wheel when driving over speed bumps. Car has 100km (65k miles).
I am going to get the driver wheel checked to make sure its not bent.
Any other suggestions of what to look for would be greatly appreciated.
Old Oct 2, 2013 | 01:15 PM
Supgee's Avatar
2003 C32 AMG
Low speed vibrations or high speed vibrations?
Low speed indicates an issue with a wheel or tire... (out of round, balance issue) its possible you knocked off the sticky weights. Could have damaged the tire liner causing it to separate (tire will hop on a balance machine)
High speed vibration? (above 60km/h) sounds like you might have damaged a ball joint, or a tie rod end.
I would start with the easy things, check the wheels/tires for balance and roundness. If all is good there, have a buddy give the wheels a shake side to side and up and down while you check the ball joints and tie rod ends for up and down movement. (car must be off the ground)
edit: One thing I forgot to mention is don't overlook any of the bushings. Control arms, sway bar links, strut mounts, etc.
Old Oct 18, 2013 | 11:07 AM
DAzzi's Avatar
'05 C55 AMG
Changed both Motor mounts, tranny mount and both wheel bearings. Everything else seemed fine. Car is super smooth now.
