transmission won't shift...
Old Nov 7, 2013 | 01:26 AM
maverik259's Avatar
05 C230K SS (sold), 06 C55 (sold), 08 Yamaha R1 (sold), 16 X5M
So my car decides it doesn't want to shift sometimes and gets stuck in like 2 or 1st gear. The shifter bezel won't switch from whatever setting im in. I can make the paddle shifters shift the what number appears on the instrument panel but nothing actually happens.
Only way to fix is to shut the car off and back on and voila, all is fine. Done it twice now in the past week.
Haven't checked for codes yet, been too lazy and scared to find out! lol plus im about to leave for 10 days to go out on Detachment on the USS Ronald Reagan with a squadron
Old Nov 7, 2013 | 01:54 AM
firstshadow's Avatar
03 C32 AMG
Check your TCU to make sure there isn't oil on it - I've read something about fluids leaking out onto the wire harness and traveling upstream to the TCU.
Old Nov 7, 2013 | 01:56 AM
maverik259's Avatar
hmm that may be likely since im quite sure im leaking at the rear seal for awhile now...losing about a quart every 2-3 months
Old Nov 7, 2013 | 09:04 AM
WaveyKat's Avatar
Something Slow
wow if you are leaking tranny oil and it leaks into the TCU it will shut the tranny down. hopefully you don't need a new tcu
Old Nov 8, 2013 | 08:26 PM
maverik259's Avatar
popped a P0715. Error in the speed sensor basically. Apparently one of my sensors in the tranny failed and started leaking fluid everywhere. So it was oil i was smelling but tranny fluid. Apparently I need a new conductor plate to be installed. I probably could've done it myself but I need the car next week and Didn't have time to order the part and look into doing the work. $1300 it's supposed to run.
