Can any W203 Coilover kit be used on our C32s
Already tried searching, so if youre going to say "use search" blah blah please dont bother.
Anyways im wondering if any spring kit or coilover kit made for the
W203 will work on our AMG spec models.
Anyone have the slightest ideaa?
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
The concern in answering your question is the use of "any". I would not use shocks from C180 on a C32. Can you be more specific? Is there a shortage of suspension parts for C32 or do you have you eye on a certain good deal that does not list compatibility with C32?
Hi Guys, Still a bit of a newb.
1. How different is the shocks of the normal say c240 and the c32?
2. how will one know when the shock absorbers are finished?
Might need shocks soon hence the question.
Thanks and sorry for the blondness
1999 E320 4matic Wagon, 2005 C55 AMG - sold, 1998 VW Jetta TDI - sold, 2006 C230 Sport - Totaled :(
2) there are many different symptoms but the easiest way to tell is go to either front or rear of the car and use your weight to push it down and let the shocks retract. It should just return to it's original position and not bounce. If the car bounces a few times then the shocks are worn. One other way to tell is visually inspect them to see if any of the hydraulic fluid inside is leaking.
