What kind of 1/4 Mile is possible with 'stage 2' mods (365 RWHP)?
oh yeah - how much for install, for stage I and stage II? thanks.
btw, what size pulley are they selling now? are the actual odps the same in stage I and II? is 190mm safe - this will be my daily driver, say 10-15k a year? much appreciated.
kevin
Kevin
that is fine that you want to wait for Evo to finish the R&D on the 190mm pully, but to be honest, I as well as some of the others are not looking into 190mm (am I right people?). I am looking at one notch up on the rung (175mm or what ever it is). I plan on having my car for a while and regardless of the initial testing, the longgevity of the engine will have not been tested.
What do guys think?
what's the standard size of the odps now in stage I, is stage II any different in terms of pulley size?
i'd be fine with the standard IMO if engine longevity is going to be a cost with the bigger pullies. this is going to be my daily driver, and i want lots of miles out of the c32 so standard for me is fine. if i want more power, stage II then?
any reason at all for decreased longevity with stage II as opposed to I? thanks.
Stage two just adds a new computer and headers I believe (plus misc. items). The major "wear" item is the initial change of the pulley, though we have been led to believe that the pulley systems should not drastically effect engine longevity.
Whenever an engine is producing more power, there is hypothetically more wear to the engine, and all drivetrain components (esp. tires
) With more fuel combusting, the pressure within the cylinder would be greater which can increase the change of all sorts of engine failures. However, unlikely at this level, esp. considering the strength of our engines. Personally, i wouldn't worry too much about stage II. Not too much power for the block so you should be fine.
EVOsport just got back to me, install is $1350 and it takes 2 days.
I guess I need to save up even more.
Kevin
$1350 for install for stage II, maybe cause the headers. do you have to take out the engine for that? on the e36 m3, header install was crazy so you had to take out the engine.
any idea how much to install stage I? thanks.
All I did was inquire about Stage I priceing.
ODPS = $1699 + $540 (install)
complet Stage I = $2890 there is no install charge for the ECU. Total = $3434
