P0341 Camshaft Position Sensor
Need your help on CEL on 2002 C32, pulled code P0341. Engine would crank but won't start everytime. Replaced with new camshaft position sensor, still the same. Any other thoughts?
CPS/fuel pump fuse or relay, did you check any of these, they're most common of starting issue..!
ZAYED,, |
Did you use an OEM CPS or an aftermarket brand?
