idler pulley size with ASP 178mm pulley kit???
Old Oct 16, 2015 | 06:38 PM
jvakos's Avatar
E63 SL55 996TT C5Z06
i meant to post this as a new thread....
my c32 is in the shop today because the smaller sized idler pulley that comes with the ASP 178mm pulley kit went bad and caused my belt to come off.
anyone know the size of that smaller idler pulley that comes with the ASP 178mm pulley kit???
I searched and cant find it anywhere. the stock idler pulley is 90mm but doens't work with the ASP 178mm kit as the kit is designed to work with the stock sized belt. the idler pulley in the needswings PSK is larger 100mm and that seems like a good kit, so amstrongly considering getting one instead of trying to find a replacement for this smaller sized idler pulley that i cant seem to find. i called into ASP and left a message as nobody picked up.
__________________
2003 C32 AMG - 178mm Pulley, Eurocharged Shorty Headers, Needswings DCAI, PLM Heat Exchanger, Eurocharged Tune
Old Oct 19, 2015 | 09:41 AM
jvakos's Avatar
called ASP about a new idler pulley, they said to just replace the bearing which is part number 6303 ZZ and is like $3 bucks. interestingly, i told him that i bought the ASP 178mm pulley kit for a C32 and he said they only make a 173mm pulley and insisted that there is no such thing as a 178mm.....never heard of the 173 before.
anyways, here is a link to www.bearingsdirect.com if anyone needs this bearing or others....
http://bearingsdirect.com/6300-serie...-shielded.html
Old Oct 19, 2015 | 05:19 PM
Morphh's Avatar
C32 amg
__________________
Try calling needswing they should be able to help u
