Rear brake rotor & pad part numbers???
There is a c32 AMG 'brake kit' that FCP euro sells with some extra stuff in it for about $500 bucks but wasnt sure if you need all that.
2034210912 - Front Rotor
005420952041 - Front Pad
210423081264 - Rear Rotor
0034203020 - Rear Pads
http://www.mboemparts.com/auto-parts...ar-brakes-scat
http://www.mboemparts.com/auto-parts...nt-brakes-scat
2 211-540-17-17 BRAKE WEAR 2
3 203-421-09-12 BRAKE DISC 2
4 003-420-30-20 BRAKE SHOE 1
5 211-540-17-17 BRAKE WEAR 1
6 210-423-08-12-64 BRAKE DISC 2
You are correct.
This MB parts site I use (links below) shows a different P/N for the rear sensors 220-540-17-17 which is a ton more expensive at $101 per sensor! The front brake wear sensor 211-540-17-17 is $5 each on this website which seems to have good prices overall on MB parts.
Do you know if those wear sensors must be replaced every time you replace pads/rotors?
--Kyle
The number that i gave you is the correct number and you have to replace them when you replace the brake pads.
The OE rotors are coated for rust. They come like that from the MB supplier.
https://www.fcpeuro.com/Mercedes~Ben...&position=Rear
Mercedes Brake Disc Rear - Genuine Mercedes 210423081264
Mercedes Brake Pads Set Rear - Akebono EUR603
--Kyle
Do you know the difference between:-
*SL65 "230 421 12 12" with code: "-P99",
Attachment 324692
*SL65 BS "230 420 04 72" with code: "P99/S",
Attachment 324693
i have SL65 BS Rotors in my hand, and they're looks similar to each other..?!?!
ZAYED,,
Enjoy.
Any feedback would be greatly appreciated!
