My C55!! Crazy suspension setup and 275 square!!!
Old 06-23-2016, 09:24 PM
dsp_tdi's Avatar
2005 C55
Just enjoy my pics. I will talk later
Attached Thumbnails My C55!! Crazy suspension setup and 275 square!!!-10441153_10154018642766489_4365768204794689756_n.jpg   My C55!! Crazy suspension setup and 275 square!!!-10569037_10154030153236489_8742397363642565207_n.jpg   My C55!! Crazy suspension setup and 275 square!!!-12717952_10154030154206489_1347144313618927600_n.jpg   My C55!! Crazy suspension setup and 275 square!!!-12998525_10154116919946489_7394877937870893756_n.jpg   My C55!! Crazy suspension setup and 275 square!!!-13001036_10154116920026489_7516980200322901235_n.jpg
My C55!! Crazy suspension setup and 275 square!!!-13015204_10154116910836489_6827789647091819206_n.jpg   My C55!! Crazy suspension setup and 275 square!!!-13015378_10154116910751489_7364699885445050363_n.jpg   My C55!! Crazy suspension setup and 275 square!!!-13043534_10154116910756489_3376703345230089083_n.jpg   My C55!! Crazy suspension setup and 275 square!!!-13051553_10154116919956489_240084095141207171_n.jpg   My C55!! Crazy suspension setup and 275 square!!!-13077079_10154116916371489_1063907414807206465_n.jpg
My C55!! Crazy suspension setup and 275 square!!!-13254064_10154205599851489_2271768811571034993_n.jpg   My C55!! Crazy suspension setup and 275 square!!!-13260171_10154205599601489_8412164663535496809_n.jpg   My C55!! Crazy suspension setup and 275 square!!!-13310412_10154205599831489_6794032529239423789_n.jpg   My C55!! Crazy suspension setup and 275 square!!!-13322214_10154205599721489_2115552394457062564_n.jpg   My C55!! Crazy suspension setup and 275 square!!!-13327579_10154205599776489_2449975195141375131_n.jpg
My C55!! Crazy suspension setup and 275 square!!!-13335714_10154205599881489_3221942556883242459_n.jpg   My C55!! Crazy suspension setup and 275 square!!!-13407331_10154243442766489_3723163921672562602_n.jpg   My C55!! Crazy suspension setup and 275 square!!!-13413664_10154243443091489_5160288482163579247_n.jpg   My C55!! Crazy suspension setup and 275 square!!!-13413749_10154243443616489_8653538656174406576_n.jpg   My C55!! Crazy suspension setup and 275 square!!!-13413572_10154243449811489_641460017820659809_n.jpg
My C55!! Crazy suspension setup and 275 square!!!-13417485_10154243449871489_5289166335787054244_n.jpg   My C55!! Crazy suspension setup and 275 square!!!-13423756_10154243449881489_1231799167947486135_n.jpg   My C55!! Crazy suspension setup and 275 square!!!-13432275_10154243449796489_2372489189433529533_n.jpg   My C55!! Crazy suspension setup and 275 square!!!-13434710_10154243449806489_7115783989613359052_n.jpg   My C55!! Crazy suspension setup and 275 square!!!-13445332_10154243449866489_6057173457880956894_n.jpg
My C55!! Crazy suspension setup and 275 square!!!-13450225_10154243442546489_6341974242151451066_n.jpg   My C55!! Crazy suspension setup and 275 square!!!-13450828_10154243443561489_7671047774353535032_n.jpg
The following 3 users liked this post by dsp_tdi:
C3Duece (02-17-2019), mig20 (01-02-2021), Robjr (12-05-2023)
Old 06-23-2016, 09:30 PM
dsp_tdi's Avatar
2005 C55
scrwmpwr (06-24-2016)
Old 06-24-2016, 03:43 AM
scrwmpwr's Avatar
c55
absolutely amazing, cant wait for the details
Old 06-24-2016, 08:40 AM
Accidental L8 apex's Avatar
2013 c63 Magnuson SCed
Suspension nerd here in for later. That's a lot of meats stuffed underneath.
Old 06-24-2016, 09:05 AM
dsp_tdi's Avatar
2005 C55
This is my setup!
Delrin rear subframe bushing
Delrin diff bushing (noise, not really good for street)
Suspension : I bought a KW Competition 2 way from a clk63 guy in France.
Rear spring : c63 kw club sport rear spring 15.3k (860lbs)
Front spring : swift spring 7k (392 lbs) 6'' 60mm with helper spring
But the front of car is to low I will update for 8'' with out helper spring. I don't really have a big ajustement up front, I need to keep the coilover nut on the top (ajustement +/- 1/4'')
Wheels : Fast Wheels FC04 18x10 Et35 with 24mm space (just for info: the front wheels don't fit out spacer, they touch the bearing cap)
Tires: Continantal Slick 275/35r18 (from canadian touring car championship)
Square Setup
I already had:
26mm front sway bar,
22mm rear sway bar,
80mm stud conversion.
Fender:
It's very tight The car is to low and the tires rub a bit in fenders, but I will go with 8'' spring without helper spring (same springs rate) The car will be go up about 3/4''-1''. I have modified the fender liner at two place. No probleme lock to lock.
I dont know why, the steering is very more easy and smooth to turn.
Alignement : I used 4 camber bolts,
caster : 10.6/11.6
Rear camber : neg 2.5 deg
Front camber : neg 4.5 deg ( I can go close to 6 deg )
The car is amazing, I need to finalise fine tunning and I need more seat time to exploit the maximum of the car. The limit has changed.
kent426 (04-20-2018)
Old 06-24-2016, 10:43 AM
Morphh's Avatar
C32 amg
Originally Posted by dsp_tdi
This is my setup!
Square Setup
I already had:
22mm rear sway bar,
Fender:
caster : 10.6/11.6
Nice I like
Old 06-24-2016, 11:05 AM
Moderator Alumni
TruTaing's Avatar
w203 m112
Man, I'm glad you're posting this on here. Fitting 275 up front on an 18x10 wheel is no small feat! Great work!
Old 06-27-2016, 03:32 AM
Khan 55's Avatar
2004 CLK55 AMG W209
That is insane man. Big up to you on doing that to a Merc
After the video.... take me for a drive in the car man. Your driving skill is great man. Congrats once again
Old 01-31-2019, 01:25 AM
Maximo55's Avatar
2002 E320
Just love this build
Old 01-31-2019, 07:02 PM
idlebumski's Avatar
C55 Wagon Midnight Blue, SL55 Brilliant Silver, E55 Designo Mystic White
even tho you spaced out 24mm, with all that neg camber, inside edge on those front wheels must be very close to the strut...
Old 02-01-2019, 09:55 AM
PJmak's Avatar
Was this a factory color on the c55?
Old 02-15-2019, 10:40 AM
Quant's Avatar
2002 CLK55
great build! you should hit up watkins glen if you are not too far from US boarder. if you let me know, would love to see another m113 in action
Old 02-16-2019, 06:23 PM
N-4Speed's Avatar
18 Avent. S, 18 GTS, 17 Cali T, 20 C8, 20 M850
Good job!
Old 03-19-2019, 01:30 AM
kaixdiego's Avatar
2005 6spd Manual C55 AMG; 2000 ML55 AMG; 1994 E420; 2008 ML63 AMG
Info on the rear subframe bushings? Great build!
Old 01-02-2021, 07:08 PM
mig20's Avatar
04 clk500 coupe, 99 ml430
Man 10 in wide wheels and they look just right. i recently got a 04 w209 coupe and trial fit my 17x10 +12 wheels with 255/40/17 tires . the back fit great but the front wheels stuck out about 30mm but at almost 0 to .5 deg neg camber
Old 01-02-2021, 07:10 PM
mig20's Avatar
This is my setup!
Square Setup
I already had:
22mm rear sway bar,
Fender:
caster : 10.6/11.6
Did you have to do any fender rolling/pulling. Iam a few years late on this post lol
kaixdiego's Avatar
what wheels are you running in those specs?
Old 01-02-2021, 07:27 PM
mig20's Avatar
some 5zigen fnorc1 i have for my nissan cars , with the use of wobble bolts to check the fitment on that wheel spec
Old 12-03-2023, 07:15 PM
hvyman's Avatar
c320
sorry to bring back. but where can i get subframe and diff poly or delrin bushings?
Old 03-05-2024, 09:50 AM
Frost36's Avatar
C55 AMG
Wow, amazing suspension setup! Thinking about going up on sway bar thickness for a tighter feel.
Quick Reply: My C55!! Crazy suspension setup and 275 square!!!
