2004 C230k stuck in park/ABS, BAS, ESP lights on & transmission in limp mode
Old Oct 25, 2017 | 12:03 AM
samman1397's Avatar
C230k
Hey guys,
I recently changed brake pads, Rotors, Ignition coils, spark Plugs and oil change on my 2004 c230k. The car drove fine for about 60 miles and then last night I tried to put it in reverse and it would not go. I manually shifted into gear and started to drive but the car will not change from first gear and the speedometer will not work either. Does anyone else have a problem like this? I was told that it could be a bad Brake Light switch??
Old Oct 9, 2018 | 12:11 PM
karayjay's Avatar
2006 CLK 350/. 2009 CLK 350/2005 Both White
Im sending my module in for repair To BBA Reman in Taunton MAss
Old Nov 15, 2018 | 07:14 PM
karayjay's Avatar
Update the sam is FINE the problem was the ABS or ESP module . The company the I sent out to repair it that said it was fixed that said it was tested was WRONG ..THEY BROKE IT and made it worse when I got it back my car was giving out even more code WHY ? because they damage it trying to fix it . I gave it to another better repair shop they attached it to the star diag machine. Well the fix was a used module !!!!! they programed it and no my car is fine.SO the company that I sent to fix broke it and made me look in another direction because I thought they knew what they we doing !! Lesson learned.. I'm getting my money back and I'm happy.
