Please help transmission issues
I have a 2003 Mercedes C32 AMG I’ve been having transmission issues first the speed sensor went out so I replaced the conductor plate on the valve body that corrected that issue about 3 months later I was driving and it just threw its self into neutral so I ended up replacing the conductor plate again along with every solenoid in the valve body it drove fine again and now when it goes to shift into fourth it shifts into neutral and the computer says the torque converter lock up clutch is slipping while driving the torque converter lock up clutch says open in first when in second and third it says it’s slipping then in fourth it goes into neutral
The following 2 users liked this post by insame1:
C32AMGfanatic (01-07-2020),
michobebe (03-16-2021)
Did you fix this issue? I’m having quite the same problem whenever it downshifts into a lower gear it has gone into neutral I also have some funky shifts going on in 1st and 2nd I’ve fixed like 3 seals in the transmission and it keeps finding a way to leak fluid at this point I am just looking into purchasing a rebuilt transmission from sunvalley
Did you find anything on this yet? Recently my radiator leaked into the tranny and i got it replaced and the tranny flushed. I heard the tranny leaks into the transmission valve body solenoid, would that cause problems?
