19" wheel size question
would these wheels fit on my C55? (ad below)
Wheel Size: 19x8.5J 19x9.5J
Bolt Pattern: 5x112
Offset: +45
CB: 66.5mm
Finish: Matt Black/Machined
Tire Size: 235/35ZR19 265/30ZR19
https://www.kijiji.ca/v-tires-rims/c...NXK7jjlRvvuxqw
Bolt Pattern: 5x112
Offset: +45
CB: 66.5mm
One more question. Found some rep BBS LMs. Here is the ad.
Wheels are 19" x 8.5 (Front) and 19" x 9.5 (rear) , 5 x 120 bolt pattern with a +35mm offset.
im assuming these should fit?
Setup #1
19x8.5J ET35 225/35/19
19x9.5J ET35 245/35/19
No problems, no rubbing, no touching. Actually you could go ET30 in front. At ET35 wheel is quite close to shock.
Setup #2
19x8.5J ET30 235/35/19
19x9.5J ET35 265/30/19
If you've got coilovers you might get some fitment issues in front. (tire rubbing front spring)
