Good buy?
Old Feb 28, 2021 | 04:31 PM
LukeC's Avatar
C300
Good buy?
Hello fellow AMG fans, for a new car I was looking at w211 e500’s as well as 204 c300’s but I was also considering a c32. I found one, a 203, with some damage and about 170k miles for 5 grand. Is this a good idea? I’m a beginner when it comes to auto maintenance but I have friends who know a lot. What will I be getting into? Should I stick to a base merc?
Old Feb 28, 2021 | 07:10 PM
C2 Turbo's Avatar
1991 964 Turbo, 2002 Black E55, 2002 Black E55 " The Beast"- 2014 E63s
a Mercedes is hard to fix on a tight budget not to mention the maintenance it would need at 170K miles. Depending on the damage, you could easily spend another $10-15,000 totaling your cost to $15,000-$20,000. Is it worth the time and hassle, is it?
Post pictures of the damage to get a better idea
Old Mar 3, 2021 | 06:44 PM
industrial6's Avatar
'03 C32 AMG | '02 CL55 AMG | '02 Ford Excursion PSD7.3 | '01 ML55 AMG | '99 C43-55 AMG | '11 E550
Totally different cars. A C300 4MATIC is great for winters and as a DD, known plenty go on and on without too much maintenance. The C32 is for throwing down power to the rear and making a good power/weight ratio. Totally different uses....
But get ready for C32 specific problems, the motor is perfect, but a leak in the intercooler, or a bad supercharger mag-clutch will put you into quadruple digits. However, there are many pro's to a C32: solid trans, motor, rear, brakes. Typical/normal problems include the rear main seal and valve cover gaskets, nothing major.
The catch:
Don't listen to me. I've put too much $ into my C32 to be trusted on this topic.
