Qustions On Springs & Catalytic Converters
Old Feb 13, 2012 | 02:51 PM
speed43's Avatar
1999 C43 Amg
Any good write ups on how to remove and install front and back springs?
And my Catalytic Converters are 10-11 years old. I dont have the second but I do have the ones up by the engine that need replacing. Anyone have a good website to buy high flow aftermarket ones?
Thanks in advance.
Old Feb 13, 2012 | 05:30 PM
speed43's Avatar
1999 C43 Amg
Will this work on the c43?
http://vr-speed.com/store/vibrant-ro...2-p-15849.html
Old Feb 17, 2012 | 06:37 PM
speed43's Avatar
1999 C43 Amg
Wow, awesome forum here!
Old Feb 17, 2012 | 07:38 PM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
You aren't getting many responses as this is a topic that has been covered in length. If you did a search you would find all of the answers you are looking for.
If you want a cat get a hold of rob @ needswings and let him know what you are looking for.
https://mbworld.org/forums/c36-amg-c...r-comparo.html
Old Feb 18, 2012 | 03:43 AM
DRBC43AMG's Avatar
I stongly recommend the KLANN type compressor. It is the ONLY one which will work without you getting in a sweat when you see the springs bulging out and ready to fly across your workshop There are some cheaper versions available but I can't guarantee they will hold the pressure of the compressed springs. Just shop carefully
Link to see the KLANN compressor at work.... easy stuff: http://www.youtube.com/watch?v=17k3t...layer_embedded
Old Feb 18, 2012 | 01:35 PM
speed43's Avatar
1999 C43 Amg
Thank you people. That's some of the info I needed. I did search but I didn't find much.
Old Mar 1, 2012 | 06:50 AM
speed43's Avatar
1999 C43 Amg
We replaced the front springs with the ones I bought from a forum member.
He said they were oem which they were comparing to the ones we pulled out.
BUT, get this, the driver side spring was cut about one turn of the spring. The passenger side was NOT! Why would anyone do that?
My front was close to touching the tire to the fender. After swapping the new springs the car went up about half inch to close to one inch. I THOUGHT THE OEM SPRINGS WOULD LEAVE A TWO INCH GAP????
So weird, the shocks where not oem. Could this be why it only lifted so little? The shocks are Monroe and they are about 7-9 years old but I'm not sure. When my car hits a bump it is pretty hard. Also if I'm parking and if I hit the side walk edge going forward the hit on the tires are very hard as if I had no springs, weird the way it feels.
Most want to lower their car but I want to raise to stock. What's going on with car? Should I buy the oem shocks? Will that lift the car at least an inch?
Old Mar 1, 2012 | 09:18 AM
w202mylove's Avatar
Carlsson CM60 EX:C36AMG'96
oem euro springs are shorter, get the us and it i'll be raised enough
Old Mar 1, 2012 | 10:04 AM
speed43's Avatar
1999 C43 Amg
Thanks. I bought them from a guy that's here in the USA which he tookmof hi c43. So I'm thinking it might be the shocks worned out?
Old Mar 1, 2012 | 10:50 AM
John-in-Dallas's Avatar
'99 C43
Shocks do not raise the car no matter how much gas pressure they have. Shocks control bounce (compression and rebound). The springs alone control the ride height of the car.
It sounds like you got a set of OEM springs for the Euro spec - and if one of them was cut, you got screwed on the deal.
There should be some members on this forum that have their US spec OEM springs laying around. Anybody?
Old Mar 1, 2012 | 11:04 AM
speed43's Avatar
1999 C43 Amg
I bought them from the member SILENCE and he lives in Rochester mn so I doubt he used euro but I pmd him to see if he has any ideas.
Btw, the spring that was cut was the old one in the car not the ones I bought from silence.
Could it be that the car silence has and mine came originally with euro springs? Or last owner switched from USA to Euro springs?
Where can I buy the front USA oem springs??? Anyone here have some and how much? Can someone PLEASE post a picture of the USA springs. The ones I have got 9 coils that circle around front top to bottom.
Oh, and silence also sent me two other spring which are taller than the two we installed. And the spring is a bit thicker. Could these be for the front?? That would be crazy if we installed the back springs in the front n vice versa!
Old Mar 1, 2012 | 04:39 PM
mbsickness's Avatar
1996 C36
Sounds like you just figured out the problem. The rear springs are slightly smallar in diameter than the front. I have a set of springs I just removed from my car and will see if the rear set is taller in an uncompressed state.
Old Mar 1, 2012 | 07:20 PM
The dealership has the OEM springs. PM MarcusF, he had a link to some MB dealership that had springs CHEAP
If that doesn't work for you PM me an offer, I have some stock OEM springs from my '99 C43
Old Mar 3, 2012 | 01:41 PM
mbsickness's Avatar
1996 C36
I measured my uninstalled C36 springs and the taller springs are for the front and they are thicker and have a slightly larger diameter so it does look like you have installed the rear springs in the front.
Old Mar 3, 2012 | 11:24 PM
speed43's Avatar
1999 C43 Amg
Awesome! What I don't get is why the last owner installed the smaller ones. That why we installed the shorter ones because that is what we took out. Maybe he wanted a real low look.
Can one more person confirm that the taller thicker springs go in front?
Old Mar 3, 2012 | 11:44 PM
Of course they do, think about where all the weight is... The springs in the front are thicker and taller to account for the weight of the engine.
