Washer Fluid Reservoir Leak
Old Feb 5, 2014 | 10:18 PM
eFifty5AMG's Avatar
2004 E55
I've had an ongoing washer fluid leak & I'm finally tired of constantly refilling the tank & seeing the warning on my dash. It looks like I've found the cause. Any recommendations or procedures to stop this leak? You can see in the pictures where the leak is coming from. Any help would be much appreciated, thanks.
Attached Thumbnails Washer Fluid Reservoir Leak-image-2984135696.jpg   Washer Fluid Reservoir Leak-image-2321503180.jpg   Washer Fluid Reservoir Leak-image-1700973128.jpg   Washer Fluid Reservoir Leak-image-529474468.jpg
Old Feb 5, 2014 | 10:31 PM
cm60k's Avatar
I think this leak caused from pump grommet....
ZAYED,,
Old Feb 5, 2014 | 10:36 PM
eFifty5AMG's Avatar
2004 E55
Originally Posted by cm60k
I think this leak caused from pump grommet.... ZAYED,,
Thanks a bunch! That seems quite logical. Where can this be ordered from?
Old Feb 5, 2014 | 10:41 PM
eFifty5AMG's Avatar
2004 E55
The grommet doesn't look too bad, could it be the pump?
Attached Thumbnails Washer Fluid Reservoir Leak-image-307121081.jpg   Washer Fluid Reservoir Leak-image-2607627638.jpg
Old Feb 5, 2014 | 11:00 PM
cm60k's Avatar
maybe the grommets looks fine, but can't assure that, cause when you put the pump, its squeezes the grommet from inside,,
Im not sure about the pump itself, but usually these grommets cause leaks once a while....
ZAYED,,
Old Feb 5, 2014 | 11:08 PM
eFifty5AMG's Avatar
2004 E55
maybe the grommets looks fine, but can't assure that, cause when you put the pump, its squeezes the grommet from inside,, Im not sure about the pump itself, but usually these grommets cause leaks once a while.... ZAYED,,
Well.. Fingers crossed, I refitted it back onto the grommet and it's no longer leaking. Maybe it was just loose? Thanks for your help ZAYED.
Old Feb 5, 2014 | 11:13 PM
cm60k's Avatar
ZAYED,,
Old Feb 18, 2014 | 10:07 PM
JohnnyRock's Avatar
1998 C43 AMG
Update on this? I've got the same issue and as Zayed pointed out, it's either the grommet(s) or pump unit itself. Not a huge deal, you can order replacements for both grommets and washer pump units (there are two, one for the headlight washers) from azautohaus.com or BMAparts.com.
Old Feb 19, 2014 | 03:46 AM
cm60k's Avatar
Fully agree,
replace the pump with grommets are best to go, avoid any kind of headache....
ZAYED,,
Old Feb 19, 2014 | 12:59 PM
eFifty5AMG's Avatar
2004 E55
I'm currently in LA, but will report back on Friday when I return. Seemed ok before I left, but can't guarantee success. Is yours leaking from the same spot?
Old Feb 20, 2014 | 02:55 PM
JohnnyRock's Avatar
1998 C43 AMG
Yes, exact same spot.
Old Feb 20, 2014 | 09:25 PM
MarcusF's Avatar
2002 CLK430
Ages ago mine sprung a leak from the exact same spot. I replaced the grommet with the part from AutohausAZ and it has never leaked since.
I typically R&R the tank for better access when changing spark plugs. I believe that is what caused my leak.
Old Feb 22, 2014 | 11:30 AM
eFifty5AMG's Avatar
2004 E55
Well, I'm seeing the lower washer illumination on my cluster again. Looks like I'll be ordering the grommet today.
Old Mar 7, 2014 | 11:10 AM
eFifty5AMG's Avatar
2004 E55
Ordered both grommets from AutoHausAZ. After replacing them, I can confidently say my reservoir is no longer leaking
