1997 C36 Engine parts for sale - Harness, ETA, Pulleys, Transmission, Ancillaries++
Old Jun 25, 2014 | 02:09 AM
rivcal4life's Avatar
92 500e, 95 E34 525I Touring
Hello,
I picked up a 1997 C36 Motor to swap into my W124 wagon. Since the engine is ME injection, and my car is HFM, I had to swap almost everything over from my 3.2. Almost everything that bolts to the C36 long block has been removed and is ready to be sold. This includes, but is not limited to:
Engine wiring harness
Late style ETA
Valve cover
C36 Plug Wire cover, though the lettering is damaged
Oil filter housing with with water cooling (a good upgrade for cars without it)
Flywheel
Blown 722.6 transmission to be used as core
722.6 transmission mount and bracket
AC Compressor and bracket
Smog pump bracket
Late style belt tensioner
Chain tensioner
Intake manifold (upper and lower, will separate if needed)
Exhaust manifolds (will separate)
Exhaust downpipes
Exhaust resonator
EGR
Fuel rail
Fan support bearing / bracket
Fan pulley / clutch / blade
Various nuts and bolts
I've also got a couple 3.2 parts like fuel injectors and water pump
I !!! DO NOT !!! Have the larger "3.6" crossover tube, any body panels, interior pieces, suspension or other parts unrelated to the engine/transmission. Sorry
I will post pictures soon, but I wanted to get this posted up ASAP. All parts are priced to move, just let me know what you think they're worth and I probably won't haggle. Please email or call/text me using the info below for the fastest response.
Thanks!
Justin
J.Poole88 at Gmail.com
(951)750-250seven
Old Jan 27, 2015 | 04:12 PM
Bump
