C43 to C55 swap. Then came the blower ;)
Old Mar 5, 2015 | 02:33 AM
benz_addict's Avatar
V12TT
Friend picked it up dirt cheap. Car needed a lot of work. Needed paint, new control arms, bushings etc. He wanted me to install a 5.4L engine from a 01 E55 AMG into his C43. So I did.
4.3L engine:
Engine to go in 5.4L from E55:
Removal process:
4.3L coming out:
the 4.3L sitting in the back. Now have to swap everything over onto the 5.4L and install the transmission.
Mating the 55 motor to the 43 transmission
Getting it ready to install back into the car
Going in...
Putting everything back together...
Got the car painted, lowered and 18 inch E55 wheels.
Old Mar 5, 2015 | 02:36 AM
V12TT
Cool pic I took of my driveway. Came out very poster-like
(S600, CL600, 2 x S55 AMG)
Time for a supercharger in the C55. Stay tuned
Just dealing with the MAF, MAP wiring at the moment so any tips and help is appreciated. Also adding looped fuel rail and bigger injectors.
Old Mar 5, 2015 | 12:06 PM
PJmak's Avatar
Which supercharger is it?
Old Mar 5, 2015 | 12:19 PM
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
looks like the OE supercharger from the m113k. I am awfully curious to know how on earth you can plug that into an N/A 5.4 AMG.
Old Mar 5, 2015 | 06:09 PM
sick430's Avatar
CLK Cabrio
cant wait to see how it comes out. What Trans are you running? Very excited, hope to do this too.
Old Mar 5, 2015 | 06:28 PM
svt ricco's Avatar
1999 C43 AMG
Old Mar 5, 2015 | 06:56 PM
eFifty5AMG's Avatar
2004 E55
Sweeet
Old Mar 5, 2015 | 07:06 PM
edwonger's Avatar
2004 Honda s2000 & 1999 MB c43 AMG
Cant wait to see how this turns out!
Old Mar 5, 2015 | 10:33 PM
benzslo's Avatar
C43 5.4, ML320CDI, Fords
Good luck getting that to run correct. The stock ecu has no provision for a map sensor, blowe clutch, or the blowoff valve. You can do some things to alter the maf signal but it won't run like a factory setup. Lots of custom work will be necessary, good luck, post results.
You might want to contact kleemann to get info on the maf setup they use for the supercharger stuff on the old me2.0 cars.
Ideally you'd want to do it on a 2000 year and have the whole car as a donor and use its me, trans, eis etc and youd still need lots of wiring to make that work and not sure if the cluster would work and still not like factory.
Old Mar 5, 2015 | 11:25 PM
Super B's Avatar
'97 c36
Very cool build, looking forward to seeing how you over come the problems benzslo mentioned. Keep us posted and thanks for sharing it's really great to see a big project on the board. correct me if I'm wrong but last project like this was winks911?
Old Mar 5, 2015 | 11:28 PM
eFifty5AMG's Avatar
2004 E55
I don't think he ever put the supercharger on.
Old Mar 6, 2015 | 03:33 AM
VMAX7's Avatar
2000 S430, 2000 S500 Both Brilliant Silver!
Top notch! Driveway pic saved*
Old Mar 14, 2015 | 08:05 PM
V12TT
Update: It starts up on stock tune and is driveable. I have the divert-er valve open and belt off. Having trouble wiring the new throttle body in so the car has no throttle response.
Old Mar 15, 2015 | 10:14 AM
squid23's Avatar
E89 Z4
I love your driveway. If you don't mind me asking, how come 3x S-class?
Old Apr 21, 2015 | 05:56 PM
Audi andrew's Avatar
02 Audi A4
How did this go? What do you need to do as far as the wireing harness?
Old Apr 25, 2015 | 08:16 PM
ProjectC55's Avatar
C43/55,2k11 Volvo S60 T6AWD,2k Audi B5 S4,95 Eagle Talon Tsi AWD 500+awhp
There is a guy on here who did the same exact setup as you with much success. He has posted a thread here in the clk55 w208 section I will look for it. He is an mb mechanic . Great job you are doing there do not give up on it! His name is Benzman
Old Aug 6, 2015 | 10:12 AM
DutchC54's Avatar
1998 W202 C43 ///AMG 5.4
any progress on the charger install??
Old Aug 9, 2015 | 07:22 AM
DRBC43AMG's Avatar
Same here, would like to hear anything new. Or has the project been ditched due to electronic hassles...?
