Anyone do the 2005 E55 AMG swap in a C43?
Old Apr 10, 2018 | 07:57 PM
Greg John's Avatar
1999 C43
Looking for info on this potential swap. Has anyone done it yet? I believe this is a W211 into th W202.
thanks
Greg
Old Apr 10, 2018 | 08:21 PM
W202 Life's Avatar
C43 AMG
I have heard of a guy doing it overseas but it is tedious....I believe you have to change out the cluster as well other things...I will ask around...
Old Apr 10, 2018 | 08:23 PM
Greg John's Avatar
1999 C43
Thanks man. I appreciate it.
Old Apr 10, 2018 | 08:25 PM
nkctb7's Avatar
2006 E55 AMG/1996 C36 AMG/1999 C43/55 AMG/2021 Toyota Tundra Crew Max TRD Sport Premium
thanks
Greg
Here you go! Apparently Mr. Kazakhstan won't share any info. as to how he achieved what some say was impossible!
Old Apr 10, 2018 | 09:33 PM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
I believe a member who went by moneyone had achieved it. Do a search and you should find the threads
Old Apr 10, 2018 | 11:04 PM
mickey13's Avatar
1999 AMG C43
not sure that there are any secrets, aside from the engine/tran swap... you have to change the electronic control modules and wiring harness. this is not a simple plug and play like the 5.4 and attempting to reprogram the computer is probably more work/more expensive than just swapping out all the modules.
aside from the c43 in the video posted above, check out this M113K Crossfire anyway article says it took more than 1000 man hours to crack the computer
Old Apr 11, 2018 | 01:11 AM
PJmak's Avatar
Moneone ended up with a 2jz in his c43.
if these people.overseas wont share a secret, thats probably because its a janky job. Also why wouldnt they post more videos of it?
Wouldnt be easier to swap a na m113 5.4 then supercharge it anyway?
Old Apr 11, 2018 | 03:42 AM
mickey13's Avatar
1999 AMG C43
I think m113k is more desirable because of internals. you can hit up the crossfire guy, but he is definitely a for-profit outfit if you are looking to do diy. otherwise, the answer is yes it can be done if if you are looking to just throw money at a project.
from a diy standpoint it makes sense to me anyway, but I'm not willing to pay someone to do it
a thought on a more current type of project might be installing batteries and electric motors on a c43. the world's first all electric w202
Old Apr 11, 2018 | 04:32 AM
DRBC43AMG's Avatar
The electric w202 exists. I saw some photos recently. Let me see if I can pull out a link... I found a photo on IG but unfortunately no details. The vehicle runs Stuttgart plates. I guess this needs a new thread.
Old Apr 11, 2018 | 12:07 PM
cm60k's Avatar
+1,
M113K into C43 really not worth it,
need a damn lot of job with more $$$$$..!!,
prefer Kleemann SC,
my friend done that 4 years ago, lot of Elec. with ECU file issues, he forced after a while..!,,
he end it up with "Kleemann SC/headers/cams/bigger injectors/(82mm) TB/LSD diff./Sl600 gearbox/ECU-TCU tune"..
-;ZAYED;-
Old Apr 16, 2018 | 07:33 AM
Some guy named James Wall just posted on the AMG enthusiasts page on Facebook a M113k swap on a C43 that he just completed
Old Apr 19, 2018 | 11:58 PM
g60wall's Avatar
2014 E63s
Im the guy from Facebook with M113k Swap. We still have a ways to go with the tuning. Just completed C32 brake swap
Old Apr 20, 2018 | 12:00 AM
g60wall's Avatar
2014 E63s
c32 brake swap
Old Apr 20, 2018 | 12:05 AM
g60wall's Avatar
2014 E63s
to answer your question, I am running it with the stock ME2.0 tuned by EUROCHARGED. Using a MAF. So I didn't swap the e55 ecu etc. But i am using the engine, with a custom oil pump setup and the trans (722.643)
Old Apr 20, 2018 | 12:47 AM
cm60k's Avatar
Waaaaaaa, is the car runs Okay..?,
good brakes..,
you are in the ROCK world Maaaaaan..
-;ZAYED;-
Old Apr 20, 2018 | 01:48 AM
mickey13's Avatar
1999 AMG C43
cool, so how do you control boost? if I'm not mistaken, the newer ECU regulates the boost.
Old Apr 20, 2018 | 10:21 AM
g60wall's Avatar
2014 E63s
I have a one piece billet block off in place of the bypass throttle body, also running a solid front pulley. So no regulation of boost is possible other than throttle input. Car is running and driving, getting few more things ironed out and custom exhaust built. Car drives great, shifts pretty hard ( likes spins the tires on a 1-2 shift with barley any throttle). Will have afr gauge on soon and will be able to figure out whats going on with the tune.
Old Apr 20, 2018 | 10:32 AM
DRBC43AMG's Avatar
Wowwww, now we're talking. Keep the info coming as I'm sure plenty would like to learn more. What's the estimated power output?
Old Apr 20, 2018 | 10:45 AM
mickey13's Avatar
1999 AMG C43
very cool, there was another member here that dropped the m113k into his c43 and ran stand alone controls. I can tell you everyone here is super interested in this build, stay active please!!!!
Old Apr 20, 2018 | 10:50 AM
g60wall's Avatar
2014 E63s
g60wall's Avatar
2014 E63s
Old Apr 20, 2018 | 11:14 AM
cm60k's Avatar
Good videos..,
are you using MAF or MAP..?
-;ZAYED;-
Old Apr 20, 2018 | 11:22 AM
g60wall's Avatar
2014 E63s
MAF
Old Sep 8, 2020 | 08:32 PM
leorb's Avatar
c200
Hi G60wall,
i am in the process of swapping my c43 with a 55 from a CLK 2003. I have a problem with the oil pump. The 43 one doesn’t align with the other engine?
how did you solve this problem? Any info would be great
Old Oct 9, 2020 | 03:03 PM
mrmatthewpaul's Avatar
W202 C43 Sadan, W203 C320 Estate,
Do you have photos and info on your custom oil pump setup?
thanks
Matthew
