PSE PUMP
I need to replace my pse pump on my C43, new ones going for $600 plus so I am going to try buying a used one off of Ebay. Does anyone have the correct part number, I have
seen 2028001048 mentioned, not sure if that is correct number. Also, does this pump need to be re-programmed ? Repairing these older cars getting to be an expensive proposition. Any help appreciated. |
make sure its for your car and suggest you post the VIN to be correct
Good idea Plutoe. My Vin is WDBHA33G2XF818281
Need part number for PSE pump. |
For your car either 202 800 11 48 or 19 48 will work without coding---all others you will be back whining!!
Plutoe,
Thanks for the part number, where is the pump? I checked under the rear seat, not there. Is it in the boot sidewall, I have had the bottom open before and dont recall any pump there. |
W202 sharing the same PSE pump with "W208/W210",
It's in the trunk, (at the passenger side), covered with sponge pop,, P/N #: "210 800 27 48"..:) -;ZAYED;- https://cimg8.ibsrv.net/gimg/www.mbw...dfed595e4b.jpg |
cm60k,
Thanks for the info and the pic, this forum and its great members have a positive effect on keeping these 20yr old cars running. |
I have one for sale, under 70k miles from my c43 parts car.
Im in Sacramento and I can ship. Also have some spare vacuum hoses It was a 99 c43 just like your too. |
My PSE is a 210 800 1148, I suspect others may interchange. What do you have and what are you asking for it.
Pm me your number and ill text you pics and details
All these below #s are the same;-
"208 800 02 48" "208 800 12 48" "210 800 11 48" "210 800 19 48" * the last & updated #: "210 800 27 48"..:) -;ZAYED;- |
Many thanks to everybody who helped solve my pse pump problem. I was able to buy a used pump from PJMac and now my door locks work. Really thankful.
PSE interchange with coding
QUESTION RE PSE PUMP INTERCHANGE
Can a same year range w220 s500 PSE pump assy interchange with a R230 providing I can Star "new initialize" it? |
Errr :confused: what does this have to do with a PSE pump?
Originally Posted by DRBC43AMG
(Post 7941681)
I thought so but didn't state it :rolf:
