C450/C43 AMG
C450/C43 Wheel Fitment Guide
Old Jan 7, 2020 | 11:03 AM
  #501
TModelle's Avatar
C190
Definitely not functional, but for the looks department, what is the most aggressive ET for a 10.5 width rear? Would ET52 fit? Lowered.
Old Jan 7, 2020 | 11:13 AM
  #502
alexasa's Avatar
c
yeah about that et53 seems to be common
some modification may be required (trimming some non essential bits from wheel well).
Old Jan 7, 2020 | 11:14 AM
  #503
Star4life's Avatar
2017 C43 AMG
hard to say. i think there was a guy on here that had et56 lowered and it worked but was tight.
yea the problem with upsizing rear for looks is on the 43, we have very small fronts in comparison so we cant upsize the front. You get massive push under steer with a large rear and small front. and with our AWD is is not close to necessary like the c63 which has rwd. my plan is to run a 275 or 285 rear with 245 front. still beefy (especially the 285) but will at least keep a closer to oem ratio.still not great oem. i bet a 255 square setup would be killer but squeezing a 255 up front is difficult. i may attempt it. we will see.
i currently am running 245/275 on my winter wheels and its working well.
Old Jan 7, 2020 | 11:25 AM
  #504
TModelle's Avatar
C190
I have run 255 front on 20x8.5 ET30 successfully. Really depends on tire brand.
I might attempt a C63 front end conversion, so I am looking at C63 wheels for the potential project. A set of 20x10.5 ET 52 rears turned up and they looked fine on the C63, but just wondering if I'm going to get any surprises on the C43.
Old Jan 7, 2020 | 11:58 AM
  #505
Star4life's Avatar
2017 C43 AMG
the 20x10.5j oem wheels are only on the coupe which has a wider rear end than the sedans do. it "should" fit but will be very tight.
Old Jan 7, 2020 | 12:26 PM
  #506
alexasa's Avatar
c
I've seen them fit - albeit not with a wide tire.
Old Jan 7, 2020 | 12:32 PM
  #507
Star4life's Avatar
2017 C43 AMG
yea the tire is everything. the sedan with 305s i saw looked pokey. but this car is hard to photograph it to see what it actually looks like in person.
Old Jan 7, 2020 | 12:59 PM
  #508
TModelle's Avatar
C190
Very true.
Old Jan 7, 2020 | 03:18 PM
  #509
mo11's Avatar
2017 C43
I have the sedan, so I can’t speak for the wagon nor the coupe. But, if I’d do it, I’d stick to +55 offset. Looking at the clearance I have, it looks like it can still handle 1/4” inner and outer width. It would definitely be better if you had height adjustable springs. My h&r springs are fixed, so when I go through big dips on the road, it rubs the fender liner (worse with passengers) very slightly though. If I had adjustable springs, it probably wouldn’t even touch.
I’m on 295/30 19, now on 19x10 +55. I’m using Michelin ps4s. I used to be on 20x10 +55, with 285/30, Continental dws 06. The 20’s rubbed the liner more. That was because of the taller diameter.
I’ll post some clearance pics of my rear. You guys be the judge if 10.5” width with 305’s would fit. I think with a +55 offset and height adjustable springs it will. You can keep the fronts at 255/35, which is what I have on 19’s, it’ll still be within the f/r 4matic ratio.
Old Jan 7, 2020 | 03:37 PM
  #510
Star4life's Avatar
2017 C43 AMG
thats really tight! any pics and spec of the 255 front setup?
Old Jan 7, 2020 | 04:21 PM
  #511
mo11's Avatar
2017 C43
Yes, VERY tight! My set up is here somewhere... But, I won’t do that to you Star... hahaha!
Fronts: 255/35 19, 19x8.5 +30
Old Jan 7, 2020 | 06:46 PM
  #512
TModelle's Avatar
C190
Thanks for the awesome pics mo11! Question though, on this picture of the rear tire - is this rubbing or is it just the way the rubber is.
Old Jan 7, 2020 | 08:04 PM
  #513
mo11's Avatar
2017 C43
That’s from manufacturing. The rubbing doesn’t happen there. It’s more on top, on the tread part when the suspension bottoms out. This is why it only happens when I speed through dips. The tire goes up and inwards when the suspension compresses and the felt like lining is where it rubs. If you have height adjustable springs, you can raise the height a little bit and it even helps with the dreaded “reverse rake”, unless the wagon doesn’t suffer from it when lowered on h&r fixed springs.
Old Jan 7, 2020 | 09:05 PM
  #514
TModelle's Avatar
C190
Thanks for the invaluable info. I will likely run 285/25R20 so that also helps. Just wondering if 10.5 ET52 is cutting it too close. From your pics, I think ET54-55 is a good number to shoot for, but looking at pre-owned right now and there's a nice set in ET52.
Old Jan 7, 2020 | 10:23 PM
  #515
mo11's Avatar
2017 C43
I remember you mentioning a c63 oem for the rears... Will it match the fronts you already have, or are you planning to do 19/20 f/r that the c63 is optioned for like the coupe? I just wanna make sure because of the 4matic the 43 has.
Old Jan 7, 2020 | 10:30 PM
  #516
TModelle's Avatar
C190
Regardless I will still match the rolling diameter front to rear for the 4matic.
Old Jan 7, 2020 | 10:45 PM
  #517
mo11's Avatar
2017 C43
Ok, for as long as you’re aware of it. Whether you go for matching 20’s up front or the 19/20 set, post some pics whichever way you go.
Good luck on the set up!
Old Jan 7, 2020 | 11:10 PM
  #518
TModelle's Avatar
C190
This is my current Rear setup of 20x9.0 ET36 on 265’s.
Old Jan 8, 2020 | 12:34 AM
  #519
mo11's Avatar
2017 C43
If you can stick out 4mm more which i think you can, you’ll be ok. That basically puts your outer rim as if you had 10.5” +52. If you have a 5mm spacer available, you can try installing that with your current wheel and be able to check clearance. From there you should be able to check if you’re comfortable on how tight it fits. What aspect ratio do you have on the 265’s?
Old Jan 8, 2020 | 12:40 AM
  #520
TModelle's Avatar
C190
That’s an excellent idea. I'm currently running 265/30. I’m only lowered 10mm, and intend to drop further.
Old Jan 8, 2020 | 01:28 PM
  #521
Unstopoulos's Avatar
2019 C43 wagon
2019 c43 Wagon with bbs lm-r
Ok so i have found my dream wheel for sale and I’m a bit confused if they will fit.
is there any way to make this combination of spacers/tired you can recommend to make these work on a stock height 2019 C43 wagon.
specs are:
front: 19” 8.5 wide and 38 offset
rear: 19” 9.5 wide and 38 offset
Old Jan 8, 2020 | 01:37 PM
  #522
alexasa's Avatar
c
specs are:
rear is too aggressive for stock ride height. but front would just need a BBS 5mm spacer to work.
You could have the rear hub machined for the 9.5's reducing the offset. Need to get them down to et40ish - et45. BBS has proprietary spacers that could easily put them right back to correct spec. Given that the bore and all that is correct.
I run 9.5 et39 lowered and the people a et36 stock height are poking pretty hard. I would not go any wider than my current set up in the rear.
you must have edited post. sorry. the rear is borderline and front needs the BBS 10mm to be safe. Should really lower it to make it work though.
Old Jan 8, 2020 | 01:38 PM
  #523
Star4life's Avatar
2017 C43 AMG
specs are:
front will need 5-6mm spacer min depending on tire.
rear is bolt on. may poke a little though. i think an aggressive fitment for rear is 9.5j with an et of 45. so pushing another 7mm may look off unless you are lowered.
Old Jan 8, 2020 | 01:55 PM
  #524
2019 C43 wagon
sorry I put the wrong offset before I edited it, I’ll attach a picture of all the wheel specs I have currently.
machine the wheel to increase offset is a concept I have never considered.. so with a 38 offset I can hope to achieve a 43-45max?
Old Jan 8, 2020 | 02:34 PM
  #525
Star4life's Avatar
2017 C43 AMG
thanks
that is tight. i may stick to 245. i only have a 9.5 rear wheel so cant do a 295 to match diameter. may stick to 245/275. and they dont make a 285/30
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
