Paddle Shifter Question?!?!
No, the shape of the pocket it goes into is different. you can modify it with a razor blade but otherwise it is not plug n play.
https://www.ebay.com.au/itm/292612172395?ul_noapp=true
Are the paddle shifters shape the same as the C43? I was thinking of getting this below?
AMG C43 3LV6 (08-11-2018)
It literally depends on what paddles are fitted.... The global worldwide optioning will vary from country to country.
But you can assume if it has the AMG insignia written on the bottom spoke, it has the larger shifters. You can match the profile with these glue on extension you are wanting.
AMG C43 3LV6 (08-12-2018)
