Pirelli Run Flats separating ?!?!
Keep in mind, if you go with PS4S, they run a little wider than most summer tires. You can compare on tirerack dot com if you enter your vehicle info.
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
Any quick links to see, since I can assume this has been done before? I tried to page throigh the fitment guide, but mostly saw aftermarket setups.
tirerack.com -> “shop by vehicle” -> enter your vehicle and zip code -> last option under product category select tires only -> after you click view results, it asks for 18” or 19” wheel and done. It will load every tire they offer with correct front and rear sizes.
Oh... I meant pictures of folks who might jave already made the switch on OEMs.
#32
