C43/C450 harsh ride
2002 C32
C43/C450 harsh ride
Hey there, I am long time Merc fan, I think I have had 100 Mercedes at the time of this writing. LOL. So my daily is a 17 GTI which I still like a lot but want to get a newer Benz. I have an older C230 which I also like a lot, but when I test drove the C450 (a used 16) and then a new C43, I was very let down at the ride quality. I have had several AMG cars, I can't remember one of them riding as harshly as this set up??? What the heck. What I used to love about these cars was the relative ferocity of the AMG packages coupled with what in the past was a pretty svelte ride...... What happened??? Kind of bummed. Pretty hard to find a Merc with anything other than a 4 banger that I would like to bring home. Anybody else share my opinion or is the general consensus that you will accept the shat ride quality for the improved handling?? TY
18in vs 19in wheels could also play a part in the ride quality. Reviews have the MY19 C43 riding a bit better although still on the stiffer side.
2002 C32
https://www.schumachermb.com/invento...wf6eb2gu125730
This is the one I drove on Weds. It did have 19"s but didn't think to check if they were run flats. Its a sweet car, definitely had the AMG side of things nailed down. : ) I drove a new one a few weeks ago at a different dealer and that car sold. Pretty sure it had 19's, I think it had the exact same wheels.
edit.... Pzeros... the are MOE or Mercedes run flats
Read the related thread below, got my answer there, thanks for the comments.
Yea it’s the run flats. If you get rid of them ride quality significantly improves. Although don’t expect luxury suspension feel. It’s just tuned to be a sporty suspension.
Not really. The improvement in ride quality by switching from run-flat to go-flat is subtle and not some major transformation of the car. 18" wheels make a bigger difference than run-flat vs go-flat.
FWIW, I have a '16 c450 and I run go-flat Michelin AS3+ tires in the Winter and the stock run-flat Contis in the summer. My car is on 19'' wheels. The suspension set up is ****ty...period ...
It's the Achilles heel of this vehicle.
I test drove a '18 C43 coupe and the suspension was much improved over my C450. Potholes and road imperfections were much less jarring in the 2018 coupe than they are in my 2016 C450. The '18 C43 coupe was also riding on 19'' wheels so it appears that something may have changed with the newer suspensions.
I'd advise anyone to get rid of runflat tires and get a slime kit and DynaPlug kit (I've successfully DynaPlug'd one of my winter Xice Xi3 tires after running over a nail on the highway). If you want high performance, then it's likely impossible to beat the Michelin Pilot Sport 4 S tires for their all-around ride, handling, comfort and tread-life combination but they can't be run in freezing temps so, depending upon where you live, you may also need a set of winter tires and/or rims.
My winter rims/tires are 18" (still staggered sizes) and I will say that the 18" setup does give a more gentle ride than the 19" setup and I suspect it has more to to with the higher profile (i.e., taller sidewall than the 19" setup), more than the difference in tires.
Sleepy914 (12-23-2019)
2002 C32
I decided to look at a different car. As much as I have enjoyed C classes in the past, from base Sport models through the AMG cars, I need a more comfortable sled. Thanks for the comments!
2016 C450 AMG Sport
Just changed out of my run flats on my C450 (Continental Conti 2s) and replaced with Hankook Ventus non runflats. Previously the ride noise was harsh and in Sport Plus the quality of the ride was horrible. Having conventional tires made a huge difference. Definitely recommend.
2016 C450 AMG
I recently swapped my stock Conti run-flats for the A/S 3+ and really didn't it made that much of a difference in ride quality. Also cracked another OEM wheel. Not happy at all with these OEM wheels or ride quality. I cross shopped the Audi S4 and regretting not buying that instead.
