final measurements for height - about 3/4 of the way down now on HAS Springs with ~1.5% increased tire diameter and 25 7/8 front fender to ground and 26 1/4 rear fender to ground. slight forward rake. Springs ride super well - very pleased.
i have ordered rear flics and new center caps. also playing around with a wheel refinish
Mods so far: KW H.A.S, Part# 25325087 (25.75 in fender to ground front and 26 in fender to ground rear) TSW interlagos 19x8 et45 front and 19x9.5 et53 rear Supreme Power Spacers 20mm front and 12mm rear w/ conical bolts in 14x1.5x47mm and 14x1.5x40mm front and rear respectively Effective offset and wheel specs: 19x8 et25 front and 19x9.5 et41 rear Continental ExtremeContact Sport in 235/40/19 front and 265/35/19 rear
Rear AMG Optics Package Rear Flics
intake baffle removal
Fender and rear deck lid badge removal
Black AMG Center hub caps and tire valve air caps Window Tint - 30% side and rear windows and 50% front windshield
Does $150 per pair sound high for spacers? The shop I called told me. That includes the installation and the parts. 10mm in front and 12mm in back. Not lowering.
$110/set is what i got from supreme. not all 10/12mm spacers work with the hubs on these cars either.
