Would you get this replaced?
Window seal on my rear passenger door/window frame is loose and feels very stiff.
Does this have the potential for wind noise or any other unwanted side effects? Or is this a non-starter. Photo below. https://cimg5.ibsrv.net/gimg/www.mbw...6eecf98f8.jpeg |
If this thing turns out to be what’s causing my phantom whistling noise, I’m going to slap myself in the face.
It's the diff.
If it is fixable under warranty then I would. never know, it could turn into a bigger issue later down the road.
Originally Posted by stockbmw
(Post 7803274)
It's the diff.
You being serious? Or are you kidding?? |
Originally Posted by waisoserious
(Post 7803287)
(Post 7803494)
The OP already knows it's the diff but looking elsewhere for his problem like his tires and windows.
The more time I've spent assessing and evaluating the conditions the noise occurs, the less likely it seems like it is the diff. Furthermore, the more time I've spent reading the accounts of those that have had diff. issues, the more I realize my symptoms are slightly different. First off, there are days where I don't experience the noise at all. Second, for me, the noise occurs irrespective of whether I'm on the throttle or off (coasting). Several of the folks that reported diff. problems stated very specifically that they only heard the noise while coasting. The third factor I've noticed recently is that the noise is always present and more pronounced on windy days. Lastly, the noise I experience sounds absolutely nothing like this:
(Post 7786791)
Sounds like "brmmmmmmmbrmmmmbrmmmm" while on 78kmh to 90km. Loudest noise at 80kmh.
Just annoying. I used to fly pass 70 to 100 just to avoid hearing this sound. |
I edited my earlier post for you.
Sounds like very low "piiiiiiii" at 60kmh hardly heard gradually increase to the throttle pedal. Loudest at 80kmh and decrease around 85kmh. |
(Post 7804800)
Whatever you are describing sounds like the problem I had. Foreman changed the propeller shaft last week as well saying it's defective and is related to the noise. When differential was changed, very faint noise still could be heard. It might be still there after the propeller shaft but it's too faint for me to care about now. |
