C43 vs c63 ride height
If so, does anyone know the differences and whether the suspension components are interchangeable. Ie will c63 springs fit in c43.
Ben.
word of advise: If you want to lower the car, be sure to do it properly. Lots of people have complained about uneven tire wear, but often, it is down to them having installed lowering springs. And since the car has a cambered suspension setup, just installing lowering springs instead of a fully adjustable suspension means you mess with the geometry causing the car to lean on the inside of the tire, negatively affecting handling and tire wear.
The front suspension components and steering ARE shared in the C43 and 63.
Only the Coupe has a wider track .
