Remote heat at start up?
Is there a way,....or does the C43 retain whatever heat / AC settings you set at start up?
Example:
If I put the heat on full blast and turn off the car,, will the heat come on the next time I start the car?
Since the app won't let you set the temperature remotely, wondering how I can heat the car up internally using remote start.
Thanks in advance !
Example:
Thanks in advance !
I believe that's the case although I've only owned mine for a month now. Also, the heated and cooled seats have some strange logic to them. I know that if I turn them on full blast they'll slowly lower the level and if I stop the car and start it again a few minutes later they are still running. If you leave it overnight they shut off completely. Not sure I fully get the logic there.
