Factory exhaust Burples/Burbles are gone.
Does anyone possibly know that if my putting an MST intake and a Race Chip S on my C450 would eliminate my poppin and crackin when down shifting or letting off the gas at high rpm? I kinda miss it now that it’s gone. I have a JB4 coming, so maybe that will bring them back? Or will it make them go away as well?
Thanks!
Thanks!
I did the bms intakes on mine and it only made it sound better, I don't have the pe exhaust though so might be different for me. I did the JB4 as well and i've gotten better sound since I started but literally just got it only on map 1 right now
The burbles should return after several drive cycles. If when you unplugged the connectors for the intake or otherwise, and didn't unplug the battery first then the car noticed it and is actively checking if something is wrong which may have triggered a soft error code. Or, the ECU is only adjusting for the change in air flow.
I've unplugged my intake sensors before without disconnecting the battery and tripped a CEL code in the ECU, burbles came back after clearing the code and around 3 drive cycles later.
