PFL205.064 with M276.823 (Oil pump solenoid defeated)
Originally Posted by ferras
this i this is what shows up when i click dynamic select - i don’t see an engine data selection anywhere i have a c450
Go back a level, do you see the vehicle data menu? If you see vehicle data menu then you are on the right screen. If you see vehicle data menu but not engine data then your vehicle might not have that option. That being said, it is possible to code it in by someone.
Basically all you need to do is to go to Vehicle (From left to right is Navi Radio Media Telephone Vehicle)
Use your scroll wheel and rotate through Time Owner's Manual Consumption Vehicle Settings... Once you find DYNAMIC SELECT, select it.
Inside you will see Individual Configuration (which is what you show in your image above so go back a level) and then Vehicle Data and finally Engine Data. If you are on this screen and only see Vehicle Data and Individual Configuration I am afraid your vehicle doesn't have it as stock and needs to have Engine Data coded in.
hey guys seen this instrument cluster on many people's car just haven't known how to get to it. can anyone help me out? thanks
Not sure if the C450 and C43 have the same menu's but for me I press the Vehicle settings button on the center console.
Button you need to press
From there you navigate to the dynamic select and once you click dynamic select you should see "Engine Data". This is where you'll see the screen you're looking for. Hope this helped
appreciate it guys but i believe i just need to get coded in because mines does not have that. thanks guys!
no problem. Given the amount of bezel your infotainment screen has, there might be a chance you have Audio 20 instead of comand, if so I wonder if coding is possible. If not, maybe retrofitting comand will enable the option for you?
