Hi folks, last month I bought C43 '17, I was driving a lot of C43's in the years but for some reason my one when I put the seat belt not pulling back is it normal and is it coming with some package when you order it?
PFL205.064 with M276.823 (Oil pump solenoid defeated)
This is for the FL, but PFL should have the same setting. Pretty sure PRE-SAFE is/was standard in the USA.
EDIT: Oh just saw you are located in Bulgaria, so not sure the state of PRE-SAFE there.
Good observation, I got curious though I think OP test driven other vehicles that had that in the same region, so maybe it was just a setting that was disabled after all?
which vehicle settings, because I didn't notice this, thanks a mate
A screen like this, as you can see on the left side of DYNAMIC SELECT there is Vehicle Settings, this is for COMAND based system though, I am not sure if you have Audio20 or COMAND. Audio20 looks completely different to this. https://images.carpages.ca/inventory...&q=75&fit=max&
That doesn't necessarily mean his car has the same options as the ones he drove before.
Well I don't have that option for the seatbelt in Vehicle Settings, probably isn't standart for c43s.. so weird but thanks anyone who try to help me with that appreciate it
P.S. I've Assistance graphic - also in the settings of cluster menu is switched on the collision (or something like that, must check later on) also I had the triangle on the dashboard when I am close to a car, BUT I don't have 299 PRESAFE as option in my list - a bit confused now
P.S. 2 I don't have Distronic also
re: triangle, guess you have anti-collision warning but not automatic braking
re: DISTRONIC, ya that isn't standard across the world I think, not only you.
re: i didn't test it if brake is applied if have to, so is just to warn me about collision nothing more?
re: Distronic I know isn't standart, i talked about 299 PRE SAFE option isn't standart - not sure if PRE SAFE is coming with Distronic
