2017 C43 spacer
2017 C43 spacer
My car have been lowered by Eibach spring, currently have 19” stock wheel.
recently added H&R spacer 15mm front and 20mm rear. The rear look perfect but the front do rib fender a bit when passing speed bump.
Could anyone advise the correct part number I do need for 10mm/12mm space for the front please, as I have checked on the forum and many of you suggested the part number on H&R won’t work. Thanks!
Received 2,652 Likes
PFL205.064 with M276.823 (Oil pump solenoid defeated)
Here is the thread I think you came across already: https://mbworld.org/forums/c450-c43-...ml#post7440991
This is the thread on wheels and spacers in general: https://mbworld.org/forums/c450-c43-...ispreloading=1
