Owner Manual and Lug Nuts. Should they be there?
2019 C43
I just got the car two weeks ago and unfortunately this is my second post on issues. It is a 2019 C43 CPO and bought from a MB dealer in Scottsdale AZ. The car did not come with an owner's manual, and I was told starting in 2019, MB stopped including owner's manual...sounds like BS to me. Is this true? The car has run flats but did not come with lugs to take them off. It seems to me that they should also be there. Am I missing something?
Received 3,933 Likes
2019 C63CS
Yes, comes with owner's manual, but the owner's manuals are available online as well.
https://www.mbusa.com/en/owners/manuals
What do you mean by comes with lugs? Wheels are attached with bolts, not lug nuts. If you mean the tools to change the wheels then no, doesn't come with it. You have to buy your own jack, breaker bar and torque wrench.
2019 C43
I appreciate your response. Here is a definition of lug nuts. "Generally speaking, lug nuts are usually found on automobiles, trucks, and any large vehicles that have rubber tires. Lug nuts may be a small component of your wheels, but they serve a very essential function of ensuring that your tires stay attached to your vehicle. So yes, this is a proper term for them, After doing research, they are supposed to come with the car. I will be visiting the dealer tomorrow and will let you know how it turns out.
2019 C63CS
Oh I know what lug nuts are. But German cars don't use lug nuts. They use wheel bolts.
If you mean you should have a lug wrench, then, no, the car does not come with a lug wrench.
Do yourself a favour and buy a good quality X type lug wrench, a torque wrench, and a decent hydraulic floor jack. Sure, you can't take the floor jack on the road, but, at home you're all set.
As for the owner's manual, my 2021 came with, plus there is one build into the Command system, and as previously mentioned, they are online. Each has their purpose, but I like having the physical copy.
Since the car is a CPO, that should have been included.
Received 2,652 Likes
PFL205.064 with M276.823 (Oil pump solenoid defeated)
Only draw back of physical copy is you can't search keywords but no big deal, just go to the good ol' index. Good to have both for sure.
2019 C63CS
Like others mentioned, CPO should include owner's manual if the previous owner misplaced it. Otherwise when the vehicle was new I think the VPC supplied the vehicle the owner's manual? Does your car have wheel locks? If so, you should also have a set of spare lug bolts in the trunk as well as well as the key.
The owner's manual is supplied by the factory. When I did ED everything was in the car already including the owner's manual. I had to remove all loose items when dropping off the car, so I carried the owner's manual in my luggage. The VPC didn't throw in another one. It's a little different when doing ED that the car has to be empty when it gets shipped as it is already in personal possession and may get searched for contraband, and customs may remove anything that isn't bolted to the car. When buying used it's not uncommon for stuff like that to be missing. May not even have all keys. Not sure CPO is required to add all the missing pieces back. A used car is still sold as-is, even if CPO.
2019 C43
Here is how it ended up
The dealership did provide the owner's manual, without the case of course, and the lug wrench was a no go. The lug wrench was a no since it was not "originally" with the car. Thanks all for your input.
2019 C63CS
That's basically it. They are doing a final quality check and restore the car to factory conditions if there are any damages. Also, they install the port installed options such as the wheel locks and Homelink mirror, and occasionally they install missing parts if there was a shortage at the factory and install last minute software updates. My car spent several weeks at the VPC, because I had some damages. I had slightly scratched the rear bumper in a tight parking lot and curbed the front right wheel. They fixed both of those and also restored the front bumper since they drilled holes in the bumper in Germany to attach the mandatory front license plate.
https://youtu.be/ERb26H7iu8c
