C450/C43 AMG
Studs and lug nut conversion
Old Nov 29, 2023 | 07:32 PM
BillinBama's Avatar
2020 C43 AMG
Has anyone done a wheel studs and lug nut conversion on their car? All my previous German cars, Bimmers and Porsches, had lug bolts and I changed them out for studs, but I'm having difficulty finding suitable kits for my C43.
Old Nov 30, 2023 | 04:59 AM
ygmn's Avatar
2015 E400 Sedan
Can I ask Why?
Old Nov 30, 2023 | 07:48 AM
BillinBama's Avatar
2020 C43 AMG
If you've ever changed wheels very often you would understand that studs are so much easier than lug bolts. Yes, I know about wheel hangers, even have some, but I pull my wheels off for brake work, and simply to clean the wheels more thoroughly. I guess it goes back to my track guys when I would change from street tires to race rubber and studs are universal for that application. German car makers went to bolts a couple of decades ago, more for cost than anything, but I'm old school and don't likenthem.
Old Nov 30, 2023 | 06:20 PM
MartinC2S's Avatar
GL350, C43 Wagon, 911 C2S
Yup, my C43 Wagon had the conversion done by the PO. I could probably reach out ask him where he got it.
Old Nov 30, 2023 | 06:38 PM
BillinBama's Avatar
2020 C43 AMG
That would be great if you could. Thanks.
Old Dec 1, 2023 | 07:37 AM
ygmn's Avatar
2015 E400 Sedan
THanks for your reasoning.
I know wheel studs and have R&R many MB & BMW tires/wheels as I worked on independent MB service shop when I was a teenager.
Old Dec 1, 2023 | 01:54 PM
MartinC2S's Avatar
Here you go:
https://motorsporthardware.com/produ...onversion-kit/
Old Dec 1, 2023 | 03:55 PM
BillinBama's Avatar
2020 C43 AMG
Thanks, just what I need. I contacted them and they gave me the proper info to order so thanks, I'm getting a set soon.
Old Dec 8, 2023 | 08:55 PM
thegreyone's Avatar
C450 & 335i 740whp
I've had mine for a couple years now. Makes switching wheels way easier. I paired them with some JDM lugs, I recommend this mod, quick clip below of mine installed:
Old Dec 9, 2023 | 09:34 AM
BillinBama's Avatar
2020 C43 AMG
Nice. I received my studs and lugs yesterday from motorsports hardware, only downside is I'd prefer black lug nuts but they were only available in silver.
Old Dec 11, 2023 | 12:41 PM
GermanCarShow's Avatar
2017 C43, 1966 230SL, 2006 Jeep Rubicon
My 1966 Mercedes has bolts. I don't know how far back it goes.
Old Dec 11, 2023 | 02:22 PM
Prodbyjr's Avatar
2019 W205 C43 Sedan - Socials @Vip.C43
BBS CIR wheels & JDM lugs on Mercedes C43/C450 AMG #w205 - YouTube
What length of conversion studs did you go with? Can you still run 5-10mm spacers?
Old Dec 11, 2023 | 07:26 PM
BillinBama's Avatar
2020 C43 AMG
68mm. I don't run spacers so I'm not sure if they are long enough for them. I've not had a chance to install them yet.
Old Dec 11, 2023 | 08:49 PM
thegreyone's Avatar
C450 & 335i 740whp
I went with 65mm studs because I didnt want the studs to go past the project kics lug nuts. I wanted them to tuck inside for the clean look.
I run a 10mm spacer in the front and no spacers in the rear on my 19'' BBS wheels and no issues in past couple years. Make sure to torque the studs to 25 ft lbs, i believe it was, and use RED loc tight and cure for 24 hrs or they will loosen up.
Old Dec 11, 2023 | 09:39 PM
Prodbyjr's Avatar
Thanks thats good to know because I run 5mm on the front and 7mm on the rear for my summer wheels. By tuck inside you mean the stud does not pass the end of the project kic lug nuts or the lug is flush with the wheel?
Is this the link? https://motorsporthardware.com/produ...ud-kit-14x1-5/
