C450/C43 AMG
Radio + other options not working or displaying
Old Feb 18, 2024 | 03:07 PM
jag0124's Avatar
*2018 AMG C43 *2014 E350 Sport *1964 220 SEB
2018 C43 W205 having an issue and I have read through like problems here and none correspond to mine. But I did do the 10 sec compress on CD eject button – nothing.
I turned off the radio (Burmeister system) by using the ‘roller’ dial button on the console – simple push and off. Went to turn it on about 2 minutes later and it wouldn’t, no sound no screen display. Tried dashboard button too – nothing also if I pick NAVI or Media, but if I backup the camera displays rear view fine and if I change anything on the temp it will display the bar with cabin temp etc. appearing as it does when working at the very bottom of the monitor. . So the monitor can display but not with all options.
So, has anyone gone through a similar thing? What is going on?
Old Feb 18, 2024 | 03:40 PM
Hungalow's Avatar
C43 2017
I thinlk you have inadvertently hit the power button just below the volume wheel thingy. Must be it if your screen still works for reverse camera. Just push start button twice with no foot on brake.. when in ignition mode..push and or hold power button for multimedia it should fire up.
Old Feb 18, 2024 | 03:46 PM
Hungalow's Avatar
C43 2017
If that dont work try hard reset on ecu...disconnect battery https://mbworld.org/how-tos/a/merced...and-tcu-388898
Old Feb 18, 2024 | 04:52 PM
jag0124's Avatar
got the answer above
Old Feb 18, 2024 | 04:55 PM
jag0124's Avatar
You're right. THANKS!
Old Feb 18, 2024 | 07:17 PM
Hungalow's Avatar
C43 2017
Np, its a pleasure to help.
