Eurocharged Misfire Nightmare (c43 18)
- Car: 2018 c43
- Tune: stage 1 at the local Eurocharged
- Problem: Misfire p0300-p0306 (random)
- When: High Rpms, pedal to floor or almost
- Story:
I will not list the location of shop as I want to give benefit of doubt but I am in Midwest USA
The shop has always been timely and straight forward Im just getting deep into this car and dont want to spend 4k just for this not to fix it
- Car: 2018 c43
- Story:
$4k for injectors is crazy talk.
Straight from MB with new fuel rail seals it's like $1100 in parts.
It's a very simple 3.5 hour job for a competent tech.
Could you maybe send a link? I found “oem” parts for close to $3k after everything, but I also found a set of 6 injectors and seal kits for about $1300 on fcpeuro and going to have to spend about $100-200 on a tool to code the injectors.
The Mercedes injectors are Bosch, there's no difference between them and MB parts (you occasionally get one that has the MB logo on it), the seal kits are 100% MB packaged parts.
Rickcross (05-21-2024)
Or, you could do what I'm doing.
I found a used set of six with fuel rails on eBay for $250, I sent them to The Injector Shop for cleaning, rebuild and piezo regeneration.
I ordered six seal kits and a drift tool from FCP Euro. My neighbor has an Autel that can program the new injectors.
TwoC400s (05-17-2024)
thanks I will be going with that as theres limited information on obd tools and whether or not they do injector coding. Also getting a special tool to pull the injectors, figured why not.
TwoC400s (05-19-2024)
