C63 Sorted - Cam Sensor Faulty
Seems mine is not the only one.
Symptoms: Orange engine diag light (bottom left fuel/temp guage) - when driving Immediate loss of power/misfire Misfire on restart enough to cause engine to shut down Worth keeping in mind. Nothing to worry about - simple fix - cam sensor was replaced. ....If you see one on the shelf at the local supermarket it may be worth picking up just in case :) |
How exactly do you change the cam sensor?
Details please. I'm sure if this has affected more than just your car, the group would like to know the facts about the replacement. I think you said it left you stranded and was towed to the dealer. How long for the fix, was the part on-hand, etc.? Thanks.
Very interesting, GREAT to hear you got good service and were back on the road quickly. That's awesome :y
For me, the light was glowing what I would call "yellow" and the car ran fine. I only heard the pinging once, thank gawd. Dealer said it was OK to drive. It was the camshaft position sensor for the right cylinder bank. My car has the build date 05/08 stamped on the door, not sure the exact day but it had to have been very early May, maybe even late April, there may have been a bad batch of sensors installed then.... :confused: |
Good info here - thnx
(I've searched for a couple days) Instead of making a new thread lll use this really old one.
What are the parts numbers for: -Crankshaft position sensor -Camshaft position sensor A&B Also where are these located on the motor? I can't find a diy on these though I've read it's not complicated and that's about it. Thanks in advance. |
2 Attachment(s)
I had a cam shaft sensor issue the other day too. My car had to be towed in and the right bank exhaust cam had lost its position at cold start and needed to be re-taught. In my case the issue did not come back.
I am wondering whether the cam sensor is about to go bad. |
Originally Posted by M-Theory
(Post 6693640)
Originally Posted by Wobble64
(Post 6693800)
Unfortunately your links are dead....
Apparently they are pretty cheap sensors it's interesting they didn't just replace it. I did learn from you I likely just can't diy pop them in and start the car once I get them due to needing a teach in. |
Regarding having to teach the cams their position after swapping the sensors - not sure. Maybe, maybe not. It is possible that the sensors do not make a difference to the position detection. I would ask my tech at the dealership to be sure.
The sensors cost 40$ a piece via mailorder. The inlet sensors are different left/right, the outlet sensors are identical. |
Thought I'd throw these pictures in for those wanting to do this. I changed all 4 just because it's easy and cheap, both inlets and exhaust.
This takes maybe 30 minutes, save your self some cash on labor (I was quoted $400 labor by MB), also in parts I totaled $170 and MB quoted me $240. $470 in savings!! Parts numbers: Cam position sensor right 0009050143 Cam position sensor left 0009050243 Cam position sensor out x2 0009050343 https://cimg2.ibsrv.net/gimg/www.mbw...9c1f79b37.jpeg Shot of you can see they are in the front corner of both sides. https://cimg3.ibsrv.net/gimg/www.mbw...7757cd51d.jpeg Left side doesn't have as much space. https://cimg4.ibsrv.net/gimg/www.mbw...58c30bc82.jpeg Only tools you'll need. https://cimg5.ibsrv.net/gimg/www.mbw...26d7d7816.jpeg https://cimg6.ibsrv.net/gimg/www.mbw...5a721cea2.jpeg They just pop out. https://cimg7.ibsrv.net/gimg/www.mbw...d60b8b900.jpeg The Inlets are easy to pop in and out but the exhausts have o rings on them so they take a bit more force. Just be sure to turn and pull/push. https://cimg8.ibsrv.net/gimg/www.mbw...323cd31b6.jpeg https://cimg9.ibsrv.net/gimg/www.mbw...78734dd40.jpeg Diff parts numbers from older to newer style sensors! https://cimg0.ibsrv.net/gimg/www.mbw...514cd015f.jpeg https://cimg1.ibsrv.net/gimg/www.mbw...7e6737122.jpeg Old and new exhaust sensor https://cimg2.ibsrv.net/gimg/www.mbw...d98396c62.jpeg Old vs new again you can see that manufacturer changed a bit, old one came out a E63 and the new ones are 2014 C63 style. |
This ^ post should be a DIY sticky for the FAQ. Good work. :y
No calibration of any sort needed after changing? Just take the old ones out and pop the new ones in? Seems like good preventative maintenance seeing how many of these go, or act up on their way out. |
hi,
how did you replace A0009050343 ? |
