White smoke at start
However, I would not expect my 2010 C63 AMG to belch _ANY_ white smoke at startup. I have now noticed it doing it 5-6 times.
It is a fair amount too, but just at start. I think it happens more at cold starts (I can't remember it happening at warm start). It does not do it EVERY cold start (at least that I've noticed).
Known "issue" with these cars or should I get it into the stealer?
It is blue/white or black/gray smoke from the exhaust that indicates a problem. Blue/white smoke indicates oil getting into the exhaust by bypassing the rings or valves and black smoke indicates an overly rich mixture condition.
The blue smoke indicates engine wear or a mechanical problem of some sort and the black/gray smoke should be diagnosed and corrected before engine damage occurs from excess fuel washing down the cylinder walls and possibly causing dilution of the oil in the sump.
You can check with the stealer for peace of mind but I think it is a normal condition of operation in colder temperatures.
