C63 AMG (W204) 2008 - 2015
car starting issues
Old Mar 30, 2010 | 01:57 PM
bluejae's Avatar
'10 C63
Exclamation car starting issues
i've had this problem for a while, and i wanted to know if it's an isolated thing. it happens occasionally, i haven't really seen a pattern.
i get in the car, stick the key in, turn it all the way to the right to start the car, and it does nothing. everything turns on like normal as if it's in the ON position, since that's what it reverts back to after you make an attempt to start the car, except the engine. from there, i try turning to the right again, and it does nothing. the only way to start the car is to go all the way to the left, and start over. then it starts up just fine. i don't have to pull the key out.
Old Mar 30, 2010 | 02:08 PM
bluejae's Avatar
'10 C63
i just saw an ad for autoscope on the bottom, "Rev Up The BMW You Love." wonder what triggered that on my thread?
Old Mar 30, 2010 | 02:42 PM
Shellbmb's Avatar
14 GL550; 14 E63s
Happens to me as well. Not sure why.
Old Mar 30, 2010 | 02:46 PM
A141inuse's Avatar
Mercedes-Benz 09' C63 AMG
any mods?
Old Mar 30, 2010 | 03:15 PM
miami1lt's Avatar
'09 C63 AMG, '10 ML350 4Matic
I've never had to turn all the way back to the left...twice I had it when I turned to ignition, nothing happened, I let off the key to go back to on, and it then started...one time led to a CEL and "limp mode". Dealership updated ECU profile and it was fine...but noted a misfire. Interesting, but sounds in your case like something between the key and ignition (perhaps isn't reading the key when put in).
I can take my wifes ML350 key and turn everything in the car on, but it says "Wrong key inserted" or something like that on the info screen...does yours say anything like that?
Old Mar 30, 2010 | 03:34 PM
bluejae's Avatar
'10 C63
hopefully the dealer can figure something out
Originally Posted by A141inuse
any mods?
yes, but this happened before the mods as well.
nope, that doesn't work for me, i have to turn it back to the left... if i leave it in the on, i could turn right all day and it won't start. i haven't tried going back one notch left from ON though.
and i definitely don't want to know that it's an ecu problem that they will have to update which will make my tune go bye bye. but it's been there since i've owned the car. just happens occasionally so i just didn't worry much about it... but it's getting annoying.
and mine gives me no messages of error.
Old Mar 30, 2010 | 03:41 PM
gsrjc's Avatar
2011 GLK350, 2010 ML350, 2008 C63 AMG
this happens to be as well. i believe i turn it all the way left too. i think i tried moving it to the on and then turning it again and nothing would happen.
Old Mar 30, 2010 | 04:17 PM
bluejae's Avatar
'10 C63
wtc, this is more people than i expected... this is a stupid problem for an MB to have
Old Mar 30, 2010 | 05:47 PM
Jons95c36amg's Avatar
02 CLK 55 AMG,09 C63 loaded with P30
No problems what so ever.
Old Mar 30, 2010 | 06:02 PM
miami1lt's Avatar
I still say its a key issue...I've turned off our ML before and open/closed the doors with the key out, and stuff stays on...I have to go back in and put the key into the on position and then back off again.
This is the same problem in reverse...just sounds like the ignition isn't reading the key properly.
Old Mar 30, 2010 | 06:16 PM
bushburninc63's Avatar
2009 c63, 2010 E63
you tried it with your spare key?
Old Mar 30, 2010 | 06:40 PM
Shellbmb's Avatar
14 GL550; 14 E63s
any mods?
No mods for me.
I agree its a key issue. Our keys are electronically sending a signal to the car to start. The act of turning the key really doesn't start the car unlike old cars where you physically had to hold the key in the starter position for the car to start. With ours, all you have to do is turn the key to the right and let go. It will still start. This is also how keyless go works. Why we don't have it (2009) is beyond me.
Old Mar 30, 2010 | 06:48 PM
bluejae's Avatar
'10 C63
didn't think about that... i don't use the spare... i'm gonna switch and see what happens.
Old Mar 30, 2010 | 09:09 PM
ATL_MB's Avatar
2010 C63
It is not necessarily a key issue. It can be a starter motor issue or any of a number of other things (brake interlock, transmission interlock, etc. etc.). Before engaging the starter, the computer checks dozens of parameters including resistance to/from starter motor. If anything is out of whack, it will refuse to start.
My wife had an intermittent issue like this on her W203 for over a year before they finally tracked it down to a faulty starter motor wiring harness. This is after they replaced about $3,000 worth of components over 4 trips to the dealer (the keys were the first thing replaced).
Old Mar 31, 2010 | 11:52 AM
bluejae's Avatar
'10 C63
that sucks
Old Mar 31, 2010 | 01:26 PM
eagle_lex's Avatar
2012 E350 4matic
big time sucks. thats what makes this forum so useful. we all learn from each other! good luck with your issue... ill be paying attention but no issues with mine so far at 3600 miles.
Old Mar 31, 2010 | 01:37 PM
gsrjc's Avatar
i'm bringing my car in for service in 2 weeks for Service B - hit the time mark again so I'll have them check out the issue and provide updates if they tell me anything.
Old Mar 31, 2010 | 01:48 PM
bluejae's Avatar
'10 C63
i'll be taking my car in soon as well... once we get more info, hopefully it helps other members with similar problems.
Old Apr 7, 2010 | 02:17 PM
bluejae's Avatar
'10 C63
update:
i've driven a week with the other key, and have not had an issue with starting the car. so i'm thinking it could just be the key that i was using before that has the problem. i really like the fact when i got the car and started it, i learned that i didn't have to turn and hold the key to the right to start the car... i remember the first time i turned the key and just let go and the car still started... but when this problem started, i couldn't do it all the time.
the same feeling is back with the other key though =)
Old Apr 7, 2010 | 02:25 PM
propain's Avatar
See Sig
Do you have a lot of weight on your key ring?
Have you tried your spare to see if the problem goes away?
Ive heard issues with stall and difficult starts due to heavy key rings pulling on the MB key while its in the ignition. Keyless go is nice for this problem.
Old Apr 7, 2010 | 02:29 PM
bluejae's Avatar
'10 C63
actually, all i have on the key ring is a usb drive. it's quite light.
when i switched keys, i just removed the trunk key from key A, and put it in key B, vice versa.
Old Apr 7, 2010 | 03:20 PM
2009 c63, 2010 E63
Originally Posted by bluejae
update:
Old Apr 7, 2010 | 08:38 PM
dmyrick's Avatar
C63
dude if I'm not mistaken you have had a lot of problems with your car. You might be in a position to negotiate a new car.
Old Apr 8, 2010 | 12:05 PM
bluejae's Avatar
'10 C63
lol have i? maybe it's because i ask a lot of questions. but i don't think i can negotiate a new car. it's not like these problems can't be solved. the engine is great, the car is great, i' just seeing if i can take care of the little things.
Old Apr 8, 2010 | 02:33 PM
TEXC63's Avatar
2009 C63, 2500HD, OlllO Rubicon
Mine does the same thing.
