Photos :: evosport 2-Piece Brake Rotors (Front & Rear) :: 2010 C63
#51
1 Post
CLK 63 Black Series, 2009 S550, 2011 Range Rover Supercharged, BMW F800 GS Anniv Edition
Brad, doesn't drilled save a bit of weight as well? But then the invariable cracking between holes is an issue - slotted only is the way to go wouldn't u agree?
#52
PREMIER SPONSOR
None fast enough!
Luke, you are right as usual on both accounts. Drilled will lose some weight, but you also lose some life. For the street it is a worthwhile compromise for the look. For the track, you would never run them. Slotted or even some flat discs are far better.
thanks
brad
thanks
brad
#53
1 Post
Gotcha- surface area vs venting/disipation of heat is always a tough compromise. I do agree though, slotted and drilled looks awesome as do those hats. I'll be getting a set pretty soon.
#54
Your car is becoming one of the nicest c63s in the PNW (along with AVB of course lol). Let us know how they hold up! I'm always wary of cross-drilled/dimpled aftermarket rotors.
#56
2009 C63 AMG - Steel Grey
Thanks again as always for all your great info.
Kjell
#57
Super Moderator Alumni
2011 GLK 350, 2013 GT-R, & 2013 RAM 1500
Well Wayne your excellent review helped me make my decision. I just ordered these from James a few days ago and hopefully will have them in a few weeks. I see Evosport also sells the SS brake lines for this as well for $299 I believe? What do you think? is it worth it to get them installed? Did you have Carb Conn install these for you or RD?
Kjell
Kjell
I did not opt for the SS lines. I was really focused on the unsprung weight reduction. If I was going to road race often I would certainly add them. RD did the work.
#58
#59
for those that installed these brake rotors, i think they are pretty bad. they seem to have less metal which means more brake fade/high brake temperature. the vains are wider than the stock ones. you get what u paid for...
http://www.youtube.com/watch?v=OHmJM...layer_embedded
#60
PREMIER SPONSOR
None fast enough!
Gaz393,
I appreciate your contribution, but you should get facts and not assumptions. There are hundreds of customers on this forum with our rotors, and not one has experienced what you posted as an example (on a 2500 HD Chevy Truck).
Further, I am sure you realize that even Mercedes offers a lighter 2-piece rotor on their own performance package? Are you implying that the factory's own upgraded performance brake package is inferior to the entry level option?
While the like and video you posted may be relevant to some products for other vehicles (such as inexpensive rotors for full size American trucks), it is simply not applicable to our product for AMG vehicles.
Brad
Brad
#61
Gaz393,
Brad
Brad
Are the rotors in stock or is there a order waiting time?
#63
Brad, Do you have replacement rotors without the aluminum hat? How much are they? Usually, multi-piece rotors like these are also investments, since you save on cost when it comes time to replace the rotor, by re-using the aluminum hat.
#64
2005 E55 AMG - - 2005 SL55 AMG - - - - - - 2006 SLK55 AMG - - - - - - 2013 Ducati Diavel AMG -
They are better since they are lighter and the cooling vents are directional to each specific side, unlike the AMG Performance Package rotors.
