Took my C63 to the track this weekend (Hyperfest)
2017 Mini Cooper S Clubman ALL4 - British Racing Green
Had a blast... but I suspect I may have slightly warped my rotors
Also.. it was 95+ out... temps were reading 255 and shifting started getting sloppy... needs additional cooling. (currently stock)
side note.. you would think you kill your car at the track.. but no, hours later, at a friends house in the pool, and another friend reversed into the front of my car....
1 Post
2021 Taycan Turbo, 2018 Radical SR3, 2021 Lincoln Aviator
I always try to avoid super hot days at the track. Very hard on the discs and pads. The discs are already drilled so there isn't much you can do.
The only thing to prevent warped discs is to take a good cooling lap with very light braking to straighten out the discs as much as possible. You can also take an extra lap before hand, so calculate when is the last lap and take the one just before on the light side (when it comes to brakes).
sucks for your bumping!
1 Post
In this case its true that the discs are probably not be warped and just spotted, or the pads themselves are borderline done and might have broken in certain areas due to very intense heat. In this case a piece of pad can be stuck at the wrong place, creating a grinding noise with a little bit of vibration.
Bottom line u need to get it checked. In all cases, unless its the pads, there is not much you can do about it. Next time also try to park in neutral if you haven't done so to avoid any deposits of hot pads on a hot disk.
I'm sorry if I seem a bit harsh, its just that I am against the concept of "it can't happen". I've had a front passenger window litteraly explode in front of my eyes (while in stopped traffic, in a 1 lane highway access). All the experts said it was simply impossible and never happened in 50 years, that you'd need an impact. Unless sharp shooters were after me...
1 Post
AMG GTBS, AMG GTR Pro, AMG GT, C63 AMG, Porsche Panamera 4S, RX-7 FC Turbo II
GT3
Its actually probably brake dust accumulated in the drilled areas. This is why most use slotted and not drilled for track days. Clean out the little holes and you'll probably be ok.
Well, in my opinion, regarding the brakes...sometimes when one is not sure what is wrong with the car...I would start with the cheapest and easiest troubleshooting option, and slowly go up if it does not solve my problem. With the brakes, first thing I would do is to go through the bedding process again...this will help alleviate pad deposits. Next I would probably lightly sand the rotors...if that does not help, then next would probably by a machine shop resurfacing the disc or replacement....
Goodluck!
Goodluck!
The jefferson, the really small one heh.. The main track had NASA racing, and the other track (I forgot its name), had Lemons running. I never had the chance to get over 105mph, straight was too short, then again, according the the instructors that were driving along (no solo rides), very few cars ever get the chance to make over 100 due to the short track straights. Lots of hard braking though, I have not used manual mode in a track environment yet, with other cars in front and behind, I was not comfy pushing limits and manually shifting yet.. In sport mode, most likely why the heat went up fast, hard braking, then jamming on the gas
As for the brake issues, it's a tiny bit of vibration and squeeling when driving at very low speeds while just tapping the brake lightly (which did not occur prior to tracking it), which is why I said slightly.. I should have said "very slight" instead It's only a mild annoyance.
[quote=jvanbrecht;4129837]The jefferson, the really small one heh.. The main track had NASA racing, and the other track (I forgot its name), had Lemons running. I never had the chance to get over 105mph, straight was too short, then again, according the the instructors that were driving along (no solo rides), very few cars ever get the chance to make over 100 due to the short track straights. Lots of hard braking though, I have not used manual mode in a track environment yet, with other cars in front and behind, I was not comfy pushing limits and manually shifting yet.. In sport mode, most likely why the heat went up fast, hard braking, then jamming on the gas
You have to be a very good and experienced track driver to get to the limits of the C63.
100mph plus feels mighty fast on that track. You will really enjoy the main track where you can accelerate the car on the pit straight. You can get 140mph with a stock C63 carrying some speed out of the last corner.
Do you really think the rotors can't warp? You must be the only person. Rotors can warp, rotors can crack, rotors can develop groves, scratches, develop glazed surfaces and they can present fatigue and even break and more.
Sounds to me like someone didn't take advantage of the cool down lap. I've been on brake demanding tracks on hot days here in California (100+ outside, not even sure what the actually track temp was) and haven't warped a rotor yet. I've seen lots of people smoke rotors and pads from instantly shutting the car off in the pits after a track session with high dollar cars equiped with amazing braking systems (lambo's, ferrari, etc). Was there water on the track?
