I'm in! and at TMPS question
Just picked up my 2010 C63 in obsidian, Performance package, etc. It was a bit of a hunt, but worth it. Now trying to control myself until break in!
Question: If i get a set of mounted snows from Tire Rack, do I need to get the TMPS sensors or can I disable the warning light on dash? |
PICS!
^ That's what she said!
Originally Posted by Even Money
(Post 4159695)
Originally Posted by roscoe95
(Post 4159507)
Originally Posted by Arclight338
(Post 4159704)
No, get the tpms sensors(you got a $60K car-$300 shouldn't bust your budget and let the car work as it was designed. Tirerack will equip the wheels with the correct units. There is an antenna in each fenderwell. Just remember NO metal valve stem caps.
Metal stem caps are a FAIL with TPMS - they will rust/seize onto the stem and then you are screwed (so to speak).
Use ABS plastic caps only. |
(Post 4159507)
Question: If i get a set of mounted snows from Tire Rack, do I need to get the TMPS sensors or can I disable the warning light on dash? jk of course:D, but I still want pics! |
| All times are GMT -4. The time now is 06:18 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
