Is the C63 transmission not track suitable?
I was using the manual mode on Sport ESP. After 2 flying laps the car converted back to FULL AUTO and before that lap was done, I could not rev past 4000rpm.
Immediately I suspected transmission overheating. So I took it easy for a lap and gunned it the second time around. The car was back to full power but no manual mode, for less than a lap...
Before I could completed the lap the engine went limp again and would not let me go past 4000rpm.
Coming back home on the highway about 2 hours later all is back to normal, including the manual mode.
I don't know if there was anything wrong with this car's transmission as the only other paddle shifted car I have taken to track was an F430 Scud and that car did not encounter problems even after close to 2 sessions of more than 10 laps each (did not count the exact number of laps). Then again, the Scud's is no auto tranny but full manual transmission.
Has anyone experienced the same?
Don't think i am not hard on the car either, i brake quiet late and pushed the car to the limits. Also the road course i tracked on is a tighter course which is known to be very hard on brakes so.....its interesting how the op has very opposite experience.
I drove the C63 pretty hard as we were trying to get the fastest lap time for this car. There was also serious brake fade after the 4th lap.
I agree with Infamouz, from how the tranny 'overheated' and how early the brake faded, in stock form the C63 is definitely designed for the street not track.
Cheers.
Unless of course this is something else, than my mistake. I don't own a CLKBS..
And MikeS54, although I experienced the same symptoms as the OP, I forgot to mention that I had done 10 laps; 5 times that of his before I experienced the same thing. This could all be relative to our locations in the world... weather/climate plays a huge part.
Just realized maybe the difference is on the track layout. I drove my C63 on a pretty high speed layout where we could reach a top speed of 130mph on 5th and flowing 3rd or 4th gear corners. There was only one 2nd gear chicane in the 12-turn lap.
Maybe, just maybe, that the transmission works harder if you exposed it to higher speeds.
The use of additional/larger coolers will definitely improve lap times and longevity on the track.
Edit; Yes, sorry. I forgot about that, my mistake!
I did note that towards the end of the track session 2 (20 to 25 minutes per session), I was losing power in WOT, but I did not take note of the rpm at the time. Also it was 100+ weather, and high humidity that day.
I'm thinking now that some guys may be downshifting way too early into braking, putting a lot of stress on the transmission, is that possible?
I just find it weird some people can make 200 laps without any issues and some can't even do 2... weak cars maybe?
I know it's not the tranny, but if I'm tooling around town in a spirited manner, downshifting early to hear the throttle blips, my oil temps will get up into the 235, 242 range.
I don't see a problem with downshifting as a means to slow the car down when you're driving around town at less than 55 mph. As long as you give yourself enough distance to slow down gradually (by that I mean allowing the car to lose speed by not pressing on the throttle) and then downshift when you are confidant that the rpms will not jump too high the trans should probably be safe.
I do, however, conceded that allowing the car to slow down by releasing the throttle as a precursor to downshifting is in effect preventing the trans from acting as an "engine brake" all by itself.
That said, I can see how the trans would take a beating if people were tracking the car and downshifting at too high of speeds.
I do not push my car when the weather is very hot. I live in a desert and the temps throughout summer range between 100-115+ consistently. But sometimes I will mash the gas and play around for short durations when it's hot (how can you not?
), and I haven't seen my oil temps exceed 227*F yet. Even though I don't have any proof for this: I fear shifting my car in manual when the weather is in the 100's*F. Even before purchasing this car, my last car had a "TapShift" mode and was a sporty type car with some good power and I chose not to shift aggressively when it was hot out.
I guess if the weather is very hot where you live, I can see how your temps get that high if you are driving hard.
I was under the impression that C63's have trans and oil coolers. I don't know what the trans temps are for our cars as I don't have a sensor and gauge for that measurement but because I have not seen my engine oil temps and my coolant temps exceed a certain number, I assumed there were coolers on the car and they were doing a good job keeping my car at a consistent temp?
Can anyone confirm if C63's have trans and oil coolers? Seems like there are some heat exchangers up front but it's not easy to see what they are.
Even though I think the temps you are seeing are slightly high, they are not in the danger zone.
I have been told that engine oil temps are often 30 or so degrees higher than ECT's. What makes me think C63's have engine oil coolers is that my car typically runs at 195*F (ECT) and 210-217 (engine oil temp). And because my engine oil temps have only reached 227*F and then fall quickly back down to 217*F when I back off the throttle for a minute or so, I assumed there was an oil cooler doing it's job.
Granted, I haven't tracked my car and realistically, I haven't driven my car that hard on city streets or the highway, so I haven't really pushed my car.
I'm sure if I really pushed my car the engine oil temps would rise above 227*F. But I think I would have to drive it very hard around town to reach those higher temps. And where I live, that would be very hard to do, even though, we don't have a lot of traffic compared to the bigger cities.
So, that's why I commented on the temps that you are seeing. It just seems like you would have to drive the car pretty hard to get those temps.
How fast do the temps drop when you back off the throttle for a bit?
I really would love to know what our trans temps look like. That would probably give a lot of information.
I have seen engine oils temp near 250 F range for extended periods with no issues. I had a E63 that shut down on me when the oil reached 280 F. I saw no warning messages, so I don't know if it was transmission temps or something else that caused the issue - I am sure it is temperature related, though, as the car sat for 30 minutes or so and then was fine.
Like others, I am perplexed why some people have had problems on track and others have not. It just can't be build variations from car to car.
I would say, though, that I have not seen anything to prove that it is transmission temps that are causing these issues. It does seem that those that use manual mode tend to have this issue more often (lending some weight to the trans temp theory), although without trans temp measurements, it is really hard to say. I have used manual mode at the track without any issue (in 100 heat), but generally use sport mode. My only problem has been steering fluid boiling over, which a dealer tech told me is pretty common on the track, although I haven't heard of anyone on the boards with the same issue.
The ambient temp when I took the car out on track was about 100F, which is hot but still not over the top.
Infamouz, yes the car was almost always at WOT except when I was braking/turning in or balancing the car with the throttle mid corner.
From how easily the brake faded (which we all agreed on) and the weak transmission in some of the cars, I can only conclude that Mercedes focused the C63 for the street more than I anticipated.
