C63 AMG (W204) 2008 - 2015
Thermostat
Old Oct 8, 2010 | 09:57 PM
jobee's Avatar
C63
Thermostat
hello guys... i havent been on the forums for a while, i use to own a SLK55 but have now moved on to a C63, i currently have ECU and a pulley kit installed on my car. Now my question is, after some internet surfing... i came across MHP upgraded thermostat just wondering what you guys think about this mod ? is it worth it ? sorry if this is adumb question... i just didn't want to get scammed since i'm a female
thanks in advance
Old Oct 8, 2010 | 10:23 PM
sflgator's Avatar
'09 C63 AMG
The C63 AMG really doesn't get overheated, which is why all the other tuners haven't developed a lower temp t-stat.
Old Oct 8, 2010 | 10:26 PM
jobee's Avatar
C63
i wanted to purchase the kleemann TB kit for my car, but i'm still not 100% it's worth the $4000 so i'm delaying the purchase... my excuse for a new hand bag
Old Oct 8, 2010 | 11:59 PM
GHAZAN's Avatar
MBUSA
you have poor taste in mods (ecu -- pulley - tb kit??)... i can only imagine your hand bags
Old Oct 9, 2010 | 08:51 AM
hhughes1's Avatar
2013 Chevy 427 Torch Red
thanks in advance
It is an oem part made by Mercedes for the Gulf States. Normal driving would not warrant the upgrade but it is great if you plan any track time in hot climates.
Old Oct 9, 2010 | 09:00 AM
Sheep's Avatar
2013 Nissan GT-R BE
Is it a Ferragamo? I really don't know enough about bags, but I am interested in your experience with the SLK55, as it rank pretty high on my list of cars after the C63 .
Sheep
Old Oct 9, 2010 | 11:01 AM
jobee's Avatar
C63
Sheep
the SLK55 was a nice car, i had installed a kleemann ECU, pulleys and eissenmann exhaust on it,i was thinking about a kleemann supercharger for it, but was debating over a new C63 or supercharged SLK55, i loved it, but i figured there wasn't enough space with just the 2 seats so i upgraded to the bigger C63...no regrets here
oh its a CHANEL
Old Oct 9, 2010 | 11:31 AM
jobee's Avatar
C63
so i guess i shouldn't even think about this, since its not really needed
Old Oct 9, 2010 | 01:04 PM
GHAZAN's Avatar
MBUSA
Interesting...is there a different part # of it?
Old Oct 9, 2010 | 01:31 PM
jobee's Avatar
C63
from what i know its just a modified stock thermostat, same part # as the ones we have
Old Oct 9, 2010 | 04:03 PM
SonnyakaPig's Avatar
MB
The thermostat would be lower temperature than stock.
If you got the aftermarket t-stat, you would have to get your tune updated to reflect the lower t-stat temperature.
The ECU tells the t-stat when to open, which then tells the fans to go on. When fans come on at a lower temp (i.e., earlier), there should be some definite cooling benefits, at least in your engine coolant temp.
Pretty standard to do on forced induction cars with V-8's. The C63, on the other hand, is naturally aspirated, but it nevertheless still generates a ton of underhood heat.
I can't see a downside to getting a lower temp t-stat, but if yo do, remember to get the tune updated.
But as others have said, unless you're tracking the car, I believe the stock t-stat will work fine. I live in 110* F + Summers and I don't think my car needs one.
Old Oct 9, 2010 | 04:06 PM
MB
I can't see the benefit unless you have larger cams and better flowing heads, headers, high-flo cats, ROW or better air boxes. And even then, I would still think the OEM TB's would flow enough air.
That said, I understand being N/A we need to find every hp we can, anywhere we can. So, if a few more hp matters, then forego the Chanel. ; )
Old Oct 9, 2010 | 10:09 PM
RStevens63's Avatar
E63
No other tuners have cams either except for AMG with the SLS, does that mean we don't need them? Hell no.
jobee, ask others who have the part in question what they think of it, who cares what others that don't have it or any experience with it say.
Old Oct 9, 2010 | 10:20 PM
jobee's Avatar
C63
i guess your right.... for $350 hell just get it, and pray that its doing its job while your doing laps at the track,
so the cams from the SLS are these just drop in parts, i'd like to teach the boys i track with in their S2000's a lesson
Old Oct 9, 2010 | 11:50 PM
sflgator's Avatar
'09 C63 AMG
FWIW - I actually have the lower temp t-stat (which is a modified oem MB AMG t-stat) and don't see any difference in temp although I do not track my car (however, I do live in a very warm tropical climate ).
Old Oct 10, 2010 | 12:25 AM
jobee's Avatar
C63
any idea what was modified, maybe a spring or something similar... if thats the case, maybe i could beg my tech to modify it... and maybe save some extra cash for .....WINTER BOOTS
Old Oct 10, 2010 | 12:38 AM
sflgator's Avatar
'09 C63 AMG
Yes, the spring and such. However, not much if any diff than stock. I think if you want more power, you should get a set of LT Headers; I'm having the MBH LT bolt-on header system installed next week!
https://mbworld.org/forums/4265595-post43.html
https://mbworld.org/forums/c63-amg-w...available.html
Old Oct 10, 2010 | 04:23 AM
RStevens63's Avatar
E63
You have a MHP Thermostat?
Your logic against it was that no other tuner made it so it must not work which is illogical I think.
Brabus put a TT V12 in a C-Class, they are the only ones, it works.
Old Oct 10, 2010 | 04:25 AM
RStevens63's Avatar
E63
The guys that run it stand behind it, I don't think that would be the case if it didn't work. The carbonio boxes for instance have been proven to show no gain on track or dyno. mthis and dodger63 did a nice track experiment for us and proved this.
A cooler motor is a happy motor.
Old Oct 10, 2010 | 08:23 AM
sflgator's Avatar
'09 C63 AMG
Hint - The "MHP" lower temp T-stat is not manufactured by MHP. btw - I never said it doesn't work (in other cars); I just said I didn't see any difference in my car but I do not regularly track my car either.
Old Oct 10, 2010 | 06:57 PM
GHAZAN's Avatar
MBUSA
So what's the modification it has to be similar to what can be done to other cars? Thermostats aren't that complex are they?
Old Oct 10, 2010 | 07:59 PM
Jons95c36amg's Avatar
02 CLK 55 AMG,09 C63 loaded with P30
Thermostat waste of money on a NA motor. I have a tune which really wakes up the car but doesnt affect oil,water temp.
Old Dec 22, 2010 | 10:11 PM
andy_c63's Avatar
2009 C63 AMG
Can you get one for $30 or I am missing something?
http://cgi.ebay.com/ebaymotors/Beck-...-/390273264097
http://www.amazon.com/Beck-Arnley-14...3074056&sr=1-1
