C63 AMG (W204) 2008 - 2015
Widest tires
Old 01-21-2011, 01:42 AM
ygtk09's Avatar
2010 C63
Widest tires
From my understanding without spacers or body work 275 are the widest, however i would want wider. What are my options?
Old 01-21-2011, 01:44 AM
Boost Gomez's Avatar
C63 AMG
285 width Nitto tires will work. Toyo and Falken has some models that might work in the 285 sizing as well.
Old 01-21-2011, 01:47 AM
ygtk09's Avatar
2010 C63
i see, i thought of putting on ps2's, what do you recommend as the best summer tire.
Old 01-21-2011, 03:19 AM
_AMG_'s Avatar
C63
Depends on what your after. More grip, longer tread wear, etc?
I would say Bridgestone RE-11, NITTO NT05 or Dunlop Direzza Star Spec.
Old 01-21-2011, 09:56 AM
OrientBlue3's Avatar
ED1 e63S
I just went with 275's rear and 245's front and I bought Contintental DW's (not DWS). They are a very good tire. Had them on my 335. Looking forward to having them put on this weekend. Hope they don't bulge off the rim too much.
Old 01-21-2011, 02:39 PM
_AMG_'s Avatar
C63
Can you take some pics after its installed?
Old 04-11-2013, 07:32 PM
gsanders's Avatar
CL55
Hey all, Just got a C63 Coupe. I am going to buy a set up 19" rims and want to use my 255/40 front and 385/35 rear. The car istock...will they work and look good? Thanks!
Old 04-11-2013, 07:40 PM
Vise_'s Avatar
2013 C63 AMG, 2013 B250
Originally Posted by gsanders
and 385/35 rear.
Take pics!
Sorry, must be a typo as 385/25 ain't gonna come close to fitting...in fact from what I can tell 285/35 won't fit either but I'll let some others with more experience chime in.
Old 04-11-2013, 07:48 PM
gsanders's Avatar
CL55
Sorry, 285/35, not 385/35
Old 04-11-2013, 08:17 PM
kg21nba's Avatar
C63 coupe EVO X(sold) WRX (sold)
How about Michelin Supersport
245/30
285/25
will it rub for 20?
Old 04-11-2013, 08:20 PM
ecampbell's Avatar
2008 BS
Dude, you really need to try the search ke on this one.
CarHopper's Avatar
E63S | X5
Supersports run wide. If you're lowered it will.
Old 04-11-2013, 09:53 PM
adibaiz's Avatar
'13 CLS63, '13 BMW 750Li
I'm running 285/25 Pirelli P Zero on a 20x10 rear w/out any rubbing.
Old 04-11-2013, 10:21 PM
CarHopper's Avatar
E63S | X5
^You lowered?
Old 04-12-2013, 02:10 AM
DuaneC63's Avatar
AMG GLC63. Audi R8
Wider rear tires may look nice and offer some nominal traction benefits, but you get vastly better performance out of an LSD. Basically you're doubling your usable tire traction width using stock sized tires without adding more un-sprung weight.
Old 04-12-2013, 04:43 AM
kg21nba's Avatar
So Pirelli wont rub even lowed the car?
Ppl saidmichelin tire is better than pirelli....= thicker than pirelli?
Old 04-12-2013, 09:38 AM
adibaiz's Avatar
I am lowered on H&R springs and no rubbing with 285/25 Pirelli tires on a 10" wheel, because i run 55 ET (offset) and yes michelin is better but i couldn't do it w/out having any issues.
Old 04-12-2013, 03:17 PM
kg21nba's Avatar
!!!!!!!!!!!!!damn, i ordered my new rims in 10.5 on the rear....................and plan to lower my car after this,so should i go with 275 instead of 285 ??
Old 04-12-2013, 03:20 PM
CarHopper's Avatar
E63S | X5
What offset on the 10.5?
Old 04-12-2013, 03:44 PM
kg21nba's Avatar
My bad, is Rear 20 x 10J ET+55.
285+ lower down, will it rub?
Old 04-12-2013, 03:53 PM
CarHopper's Avatar
E63S | X5
^That is identical to what adibaiz has then. Look at what he says, he had to run the pirelli in the 285 because the michelin would lead to "issues"..
So seeing as you have the same wheel specs I can say you'd be able to run the pirelli in the 285 but if you got a michelin pss I'd run 275.
Old 04-12-2013, 03:55 PM
Goni C63's Avatar
C63/X5/ML/YUGO
I just got mitchelin pilot ss 245-40-18 & 265-35-18 perfect set up no rubing even they run so wide and I have stock set up very happy with them so far
Old 04-12-2013, 04:00 PM
CarHopper's Avatar
E63S | X5
From what I've seen around here that is one of the preferred setups for the PSS
Quick Reply: Widest tires
